Sponsored by: CARiD
Battery cable broken... fix??
Old May 8, 2010 | 11:46 PM
awdjunkies's Avatar
Okay so I'm going out on a limb here and asking a question that might be dumb but heck, I'll ask it.
For sometime now I have had problems starting my runner(1990 4runner 4x4 v6). Anyways, I had the battery replaced and the problems seemed to end. Well a few months ago it happened again, no start unless I got a jump(Which quickly started each and every time). Well I figured I would check on it myself and this is what I found:
The Thick wire that goes to the positive was cut/rigged. As you can see from the picture I posted/found on here. So it doesn't have the big metal bracket if you will that attaches to the terminal(As I have circled here with my keen skills at MS Paint). Sooo after all this, my question is, can I replace this wire or is there a way to purchase that metal piece so that I can install it to the terminal?
Also, without that metal piece attached to the thick wire the install makes it difficult due to it being shorter (Because of the broken/non-existant metal piece)
Attached Thumbnails Battery cable broken... fix??-pos-thick-wire_4runner.jpg
Old May 9, 2010 | 12:00 AM
Elton's Avatar
strip the wire back some get a couple copper lugs take some solder fill the inside of the new triminal about half way now hold it with some pliers heat it with a torch tell the solder melts then jab the wire in and hold it for a few secs
Old May 9, 2010 | 09:12 AM
awdjunkies's Avatar
Awesome!! Thank you, I am assuming I can get these^^ at any autozone/kragen auto parts store.
PS: Thanks for the quick response Elton.
Old May 9, 2010 | 11:28 AM
Elton's Avatar
ya any parts should carry those
Old May 9, 2010 | 03:08 PM
wyoming9's Avatar
Red face
Why would you use side terminals. i think that is alot of your problem make sure you coat it so it does not corrode
I guess to each his own.
If you are able to get a good solder joint with crimp on lugs i will be amazed
Old May 9, 2010 | 03:12 PM
yotaman85's Avatar
apparently you read my thread!! the same cable i used in that thread should be a great replacement for that stock broken wire... just make sure you get it long enough..
Old May 9, 2010 | 03:55 PM
mrddk92's Avatar
i bought new terminal ends and just cut my old canles back a few inches and spliced the cables together and soldered them together and then used shrink tubing and electrical tape. its worked great for like a year..
jasonty
41
Dec 23, 2018 01:00 PM
montanatruck
Feb 26, 2017 07:07 AM
altydog
Jul 28, 2015 10:20 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
CanRunner
Jul 20, 2015 01:29 PM
