Sponsored by: CARiD
burnt valve,bad seat?
Old Apr 25, 2010 | 05:47 PM
jshguinn's Avatar
Exclamation burnt valve,bad seat?
to start from the beginning,i bought this jewel and drug her home with a bad oil pump no bearings left in bottom end,the engine was junk.Soooo i used the block cleaned painted and honed,replaced pistons,crank,rods,cam,rockers,basically anything that could have been damaged by the oil pump faliure. I drove the truck adjusted valves and put around 2k miles on engine ran good started ticking no miss sounded like rocker adjusted again got worse ok maybe exhaust leak,pulled manifold started engine no4 cylinder is shooting a flame out. i cant find anything on a search and i need some help someone said could be weak spring?
icentropy
Sep 16, 2020 02:47 PM
jasonty
41
Dec 23, 2018 01:00 PM
sojourner567
Jul 16, 2015 08:52 PM
Poncho0206
Jul 10, 2015 06:21 PM
icentropy
Jul 9, 2015 02:12 PM
