Sponsored by: CARiD
Quick Locking Hub Question (86' 4Runner)
Old May 9, 2010 | 08:15 PM
Swimmerboy2112's Avatar
I have a 1986 Toyota 4Runner 4x4 with the locking front hubs. I'd like to be able to engage 4 wheel drive but for whatever reason i cannot turn the hubs all the way to the "lock" position. The passenger side turns about 90% of the way there, and the drivers side turns about 40% of the way there. I tried hitting them with PB Blaster and using a wrench to turn them but no luck. People suggested that i rebuild them, can i just unbolt the 6 bolts that hold the hub locking assembly on? Or do i need to jack up the truck and remove the wheel first?
Any help would be greatly appreciated!
-Brian
Old May 9, 2010 | 08:18 PM
scuba's Avatar
You don't need to remove the wheel to get at the hub. Sounds like something is maybe bent or broken inside of them.
Search "manual hub rebuild" I guarantee you will find good pictures and directions on the process of taking those apart and fixing em up.
Old May 9, 2010 | 08:19 PM
scuba's Avatar
Or just read this
Old May 9, 2010 | 08:22 PM
Teuf's Avatar
Get a shop manual, n grease them up, that easy.
Old May 9, 2010 | 08:24 PM
Thanks guys! I'll get at them tomorrow (temp pending). I really appreciate the help. I was going to get a shop manual but it was too late tonight.
Old May 9, 2010 | 08:31 PM
scuba's Avatar
The only shop manual you'll ever need
http://myweb.dal.ca/is353832/93fsm/
Old May 9, 2010 | 08:34 PM
Originally Posted by scuba
the only shop manual you'll ever need
lifesaver!!!
Old May 9, 2010 | 09:30 PM
Teuf's Avatar
Amazing Scuba, thanks too.
Old May 10, 2010 | 08:39 AM
How do you guys get the black cover off?
Old May 10, 2010 | 08:44 AM
scuba's Avatar
The 6 bolts that hold it on?
Old May 10, 2010 | 09:03 AM
Not that one, the round shroud, it wont let me get to the bolts behind it.
Old May 10, 2010 | 09:38 AM
Come on guys! I wanna get this done today!
Old May 10, 2010 | 09:57 AM
Ardent's Avatar
there are 6 bolts on the hub face. take them out, then you can get to the other 6 bolts on the hub body- you probably don't need to go that far though.
Old May 10, 2010 | 10:02 AM
4Crawler's Avatar
http://www.off-road.com/offroad/arti....jsp?id=399668
If there is a cover around the hub, may need to remove the wheel to get it off first.
Old May 10, 2010 | 10:16 AM
Teuf's Avatar
If you want to get it done, get a manual or google it.
Old May 10, 2010 | 10:22 AM
Thanks, i thought i had to remove the wheel but i wasn't sure.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
ItsJustD
Jul 7, 2015 07:49 AM
Jnkml
Jul 6, 2015 01:20 PM
