Sponsored by: CARiD
3.0 swap to 22r
Old May 6, 2010 | 06:23 PM
Rip's Avatar
Rip
3.0 swap to 22r
Does anyone have info the 3.0 is junk I would like to put a 22r I know it will not bolt up so should I throw a 4 banger trans and t case in it that sounds the easy way to me? will drive shafts fit?
Old May 10, 2010 | 08:37 PM
NorCalWheeler's Avatar
To be honesty why would you want to swap from a 3.0 to a 22r. I understand the 3.0 sucks but why a 22r, why not a 22re? Or even the 22re with the turbo lol jk
Old Jun 19, 2010 | 07:49 PM
Tokeman's Avatar
3.0 swap to 22r
Im not sure the tranny and t case will bolt in. It should. it all looks the same. But if you are luckey you can find out what tranny your 3.0 has behind it and see if there was a turbo 22re made that year w your same trans. Then serch out the bellhousing they bolt right up to any 22r or re. the motor mounts are way back so you must weld aftermarket 22r engine mounts on the frame. they come pre fit for $30 ea just weld em in. Good luck
Old Jun 20, 2010 | 08:53 AM
RobD's Avatar
You'd be looking at new motor mounts and crossmember for the transmission, minimum.
Bolt in a 3.4 instead. It fits the engine bay, will bolt up to your tranny, and has more power/fuel economy than the 3.0. It's been documented a hundred times and would probably take less time than the swap to the 22R.
http://www.andrewzook.com/content/view/22/37/
tobylab
Jan 18, 2016 07:06 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
keithporter83
Jul 24, 2015 07:37 AM
tobylab
Jul 12, 2015 12:53 PM
Coreyr384
Jul 10, 2015 11:13 AM
