Sponsored by: CARiD
91 P/U LOUD creaking/popping in front when turning, CAN'T FIGURE OUT!!
Old May 9, 2010 | 03:09 PM
McAtee's Avatar
Exclamation 91 P/U LOUD creaking/popping in front when turning, CAN'T FIGURE OUT!!
I have a 91 Pickup DLX and every time I cut the wheel in either direction there is a very loud popping and groaning coming from somewhere in the front end. I have checked all the moving areas and I can't find any rub spots. I also greased and lubed EVERYTHING and still have the issue
Any suggestions are welcomed
Old May 9, 2010 | 03:12 PM
freddy's Avatar
It happened to me too.
Old May 9, 2010 | 03:18 PM
2DoorRunner's Avatar
Steering stops.
Try seaching a little. This is covered at least once everyother week.
Old May 9, 2010 | 03:20 PM
swampfox's Avatar
have you done a search, it was covered not to long ago. it might be the turn stops needing greased.
Old May 9, 2010 | 03:21 PM
The part circled in yellow hits the crecent shape.
You can grease them everyonce in a while, or get new rubber end caps from the stealership.
There are 4 stops total, make sure you get them all.
Old May 9, 2010 | 03:22 PM
McAtee's Avatar
I tried the search before I posted but got nothing, I don't want to be "that guy" but I still haven't totally figured this site out yet.
Old May 9, 2010 | 03:27 PM
Kiroshu's Avatar
Its prob the steering stops. Its extremely common on toyotas. You can put some lithium grease there and it will quiet down for a little while...
Old May 9, 2010 | 03:29 PM
Its understandable, the yotatech search sucks. What i do is go through google. For example type in "noise when turning yotatech" and it will almost always bring up a yotatech thread about it.
Old May 9, 2010 | 03:38 PM
McAtee's Avatar
That was it, thanks very much I will grease them up pronto
Thanks for the advice as well
Old May 9, 2010 | 03:43 PM
thefreqofnature's Avatar
Originally Posted by 2DoorRunner
Its understandable, the yotatech search sucks....
!SACRILEGE!
but true
Old May 9, 2010 | 03:45 PM
...I don't want to be "that guy" ...
Neither did any of us when we started posting but most of us were.
Old May 9, 2010 | 03:59 PM
swampfox's Avatar
the only way to learn is to ask questions. so don't worry about it.
Old May 9, 2010 | 04:20 PM
^true, but not true at the same time. Most of what i know has been taken from countless hours of reading over this site. Oh and wikipedia
Old May 10, 2010 | 04:30 PM
McAtee's Avatar
I am getting the hang of things, I just figured out through another thread that I have to replace my catalytic converter, very good to know.
Old May 10, 2010 | 05:08 PM
tpaine14's Avatar
read toyotanation faq must read in the 89-95 forum, the faq on these trucks here and the toyota bible on pirate and after a few hours you can go from asking questions to answering and knowing what will be going to on your truck in what order an x amount of miles.
Old May 10, 2010 | 05:11 PM
MaK92-4RnR's Avatar
if could be your steering stops, OR your CV joints binding because they need to be replaced.
Old May 11, 2010 | 08:00 AM
Lloyd7703's Avatar
CV's?
Have a 2000 4Runner and I am having getting a quick pop/knock sound (and feel in the wheel) whenever I turn to the right past about 50% (and moving forward). After reading up here, my hunch is that it is the CV joint and not the steering stop (I had that issue with a toyota I owned a long time ago and this sounds different). Is there any easy way to determine if the CV joint is bad without taking it to a mechanic to diagnose?
Isaac
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
lledwod
Aug 30, 2016 01:03 PM
smiley52
Jul 11, 2015 05:16 AM
