View Full Version : Newbie Tech Section
- HELP! Stalls in 4WD mode.
- 92 22re.. no knock sensor found. is there one?
- What is this elecrtical PigTail?
- Priming engine oil system
- Chasing HEAT demon in 94' 22RE
- 22re surging problems unique
- How much to fix burnt exhaust valve on 2003 hilux 3.4l v6
- two questions
- 20r has no power
- new to the forums here
- Broken rocker assembly end piece
- Newbie owner dipstick question
- loud 22re, fan clutch question
- newbie diff question
- T100 rear springs on pickup?
- Will tires affect gears
- Advice Needed-Carb Cleaner in Intake Ports
- got a couple random plugs where do they go? 22re
- Rebuilt long blocks and no timing cover
- Regearing question
- Shock length
- About to drill t-stat. Need help
- Help with this part?
- cat/02/exhaust options
- 22r to 22re swap in progress
- '92 22re in an 85, knock sensor error code
- 2004 Taco value, for 1999 or 2000 4runner
- 4" lift question?
- 1984 front axel leaking
- Weird noise in dash
- Newbie Needs advice on an engine knock
- 91 3.0 hard start and wont idle after 10 mins
- headers/matching exhaust
- Can't get steering column bolts back in!
- Repowering 91 yota 4x4 with 1977 20r engine.
- Gargling nails
- question about new ome lift
- 3rd members
- 1986 Toyota pick up tranny problems
- Toyota Vehicle ID Manual
- add coil spacer 1"-1.5" leveling kit to OME suspension lift?
- 2000 4Runner leveling kit - stress on CV? - need quick help
- lsd automatic to manual
- new to yotatech! need some input
- anyone no what the dash colour or code's are?
- Are my gears going out?
- brake problem
- Upgraded steering?
- Is it Possible to Convert a W56 Transmission
- Please evaluate this rig ... good deal or pass?
- chrome air intake
- Another "Click" when starting question
- Trying to Remove Brake Rotor, Having Issues
- Another rear window problem thread 93'
- Need Advice for SAS and building a rig on a budget
- 22r Manual to auto trans swap?
- '04 Sequoia with broken rear latch
- 22r extreme rich condition
- Help With Determining If 22r Is A 84' or 85'?
- 3vze oil dipstick
- 87 Toyota making weurd noise
- Throttling idle / high RPM's w/ brake pedal
- Newbie with "getting started" questions.
- New here, posting mpg and need a some help on an oil leak.
- Ignition coil resistance to high? maybe thats problem?
- Newbie with first Tacoma
- Different VSS but same transmission?
- 1990 4runner automatic v6. engine knocking, underpowered and bad mpgs
- First time Yota owner- making sure it won't die!
- 22re power mods for around 200
- 88 4runner 22r driveshaft compatibility with 86-95?
- Supra AFM Details
- wire harness swap: 22R to 3.0 v6 conversion
- home made rock sliders
- 91 4runner starts great idles at 1500-2000 most of the time
- my first yota have a few poroblems idle speed and other problems
- Fair price for gear setup?
- 86-91 what parts interchange
- Newbie with 92 pickup questions
- HELP ! solid front axle swap
- If you re-gear the rear diff, do you also need to regear the front to match?
- Whats the easiest way to get to my clutch
- Need 20R engine head, 77 Chinook
- Quick grille question
- What do these symptoms mean.? 1979 20r
- Thinking about buying a yota
- 86 4Runner 22RE dizzy question
- engine burning oil...
- Cleaning MAF on 3rd gen 4runner 3.4
- Cab smells like fuel when first started
- 22r Fuel Line Routing
- Rear Drive Shaft Replacement
- Radiators - Alum. vs Brass/Copper
- New to forum
- Noob saying HI
- bumpy ride = oil pressure light
- 27 spline axle as a spare
- Ok! What should or shouldn't be upgraded while it's all apart?
- Welded rear ends
- Anyone know of online source of parts for Belts (Landcruiser)
- Better build? 1985 vs 1994
- 88 4runner 1st gear noise
- simple bulb change leads to chaos..1
- Stripped EGR valve/nut
- Not so obvious items that should absolutely be replaced because they are so cheap!
- New YotaRunner Owner, Few Questions???
- 22r to 22re engine swap fuel help
- yet another 1987 4runner miss/rough running
- pickup and T100 IFS similarities?
- Trying to drop A/T pan...
- 22re valve adjustment
- Help me identify this part ...
- Cooling Help
- 96 Toyota 4Runner Transmission Whining
- MSD,Crane,Jacobs ignition box any thoughts?
- 91 4runne wont start.
- Defeat/Disable Factory Alarm- 1993 Pickup
- Noob needs help - DIY Bed Liner, also MPG
- LSD adjustment ???????
- 2003 Tacoma Rear Axle swap into 1995 4runner
- 86 4runner not starting
- best 02 sensor for 22re
- 1994 Toyota 4Runner SR5 V6 4X4 Clutch Replacement
- i have afew questions to ask about a 82 dualcab hilux
- 86 Runner AFM (air flow meter) issues
- Headliners
- Rear view mirror
- 90 4runner doesnt start
- help finding right part! carb related
- 86 toyota 20/22r shift problems
- How well do ball joint spacers work
- Broken timing chain guide
- 1FZFE engine removal question
- Battery: dual or one big battery
- Head Gasket again or another Motor 22re help
- help with Dyna 2l alternator
- Shocks to use with OME 891
- standard to auto transmission swap
- 3vze problems!! 92 pickup !!
- 96 Taco lift help
- Water in oil (And I know you're thinking gasket)
- making my 22re faster
- 4 Runner P O 770 code
- recurring vibration feels like driving on corrugated road
- Did a new cap and rotor cause this?
- 95taco cruise control not work
- Tried to raise my idle and nothing happened
- Help finding the correct 22r carb rebuild kit
- Proper Lift on 1988 4Runner?
- coolant spray
- About to start a 302 swap: 87 2WD
- Speedometer change cable to electronic??
- Stripped oil pan plug! 87' 4x4 pickup
- 20r upgrades - how much hp and torque you think?
- Replacng 22r Crankshaft main seal
- Need help with gauges
- Brush/Bull Guard Fitment 99-02 & 03-UP
- gearing setup tranny/rear diff etc help
- What to seafoam?
- 90 4runner very weak Help
- 99 4Runner Cali Spec strange cold start issue
- Steering arm stuck
- Where Can I Find a Shifter Boot???
- 2012 tacoma supercharger
- What do I need for dual t-cases?
- 20R Camshaft Upgrade Question
- Dealership, Firestone, 3 local mechanics cannot solve stalling/idle problem
- rear leaf install guru needed.....
- G52 tranny fluid?
- 85 toyota 4runner 22re idle/running problem
- 3rd Gen 4runner grinding when turning
- 1983/84: possible rod issues
- What Cb to go with ?
- No compression in cylinder 2!!
- dimmer switch
- Noob to yotas has question about 3rd gen 4runner build.
- Tie Rod ends, Ball Joints upgrade?
- 1st gen 4runner vibration when turning
- Now leaking oil *sigh*
- Fipg
- *Video* My Experience With 22RE Timing Chain/Head Gasket/Pitted Rockers&Cam
- New HD Marlin Crawler clutch in, now I can't get into gear... Please help.
- 79OldTruck
- 91 4runner problem
- Gas leak
- My 22R hesitates when the engine heats up / gets warm
- 1st Gen 1980 Transfer case won't shift into 4 Hi
- Truck does wierd stuff on startup
- body panel interchangeability
- Vacuum hose diagram 4ac
- 93 pickup WONT START????
- Found 2000 4runner 3.4 5speed couple ?'s before I check it out
- New to me truck with no spark
- 1999 4runner cigarette lighter socket blowing fuse
- carrying a ladder on a 4runner?
- AC belt tensioner?
- New to the forum. Just bought a 99 runner. has 142k and original timing belt?
- 'Nother parking brake ?
- pretty noob question as to a knocking motor
- 1999 4Runner CEL comes on when in 4 wheel drive
- 95 Toyota 4 Runner Trouble Shooting
- Is a lift needed for these tires?
- Integration relay testing
- 5vz-fe into mk3 supra
- Differential leak
- Compatible Parts?
- Lower Ball Joint
- 'Aussie Bullbar' Winch Mounting Q's
- Painting/Customizing 90's SR5 Rims
- Wont go into 2nd now
- 1990 toyota pickup trouble
- Shorted Alt. connections... oops
- Tipped my 4runner.... possibly parting out
- question about 1991 and 92 truck rearend compatidility
- Which Transmission do I have?
- Questions on which model 4runner....
- Whining sound from under plenum
- Diff drop with no lift....
- 1987 Toyota Hilux 22R-E (rte) build questions.
- help
- Vacuum line and intake cleaning
- marine/jeep roll bar speaker pods. 1st gen runner
- V6 Brake Upgrade
- 3vzfe oil filter and drain plug
- stumbles and misses then starts to over heat
- Super loud ac blower; almost no airflow
- Lift kit
- Help 94 4 runner front diff carrier bracket broke!!
- Circuit breaker
- changing front windshield
- rough running
- sticky throttle help
- 80 amp fuse
- missing when warm
- Identifying ECM (and engine) model year
- New 4runner owner
- Trouble removing idler arm.
- 95 4 Runner Losing coolant
- Accessory line has no power.
- oil pan leak
- electrical problems
- Body Work
- toyota fiberglass bed
- 5VZ-FE crank compression
- Dead cylinder
- Coolant problems, possible blown head gasket?
- P1600 Code
- Gears
- '07 2WD control arm jacking point?
