Sponsored by: CARiD
Gas leak
Old Jul 14, 2012 | 12:15 PM
dw1031's Avatar
Gas leak
I have a 86 toyota pick up 4 wheel drive. Sr5 22r.
the #1 injector has a crossover tube linking all the injectors. This screws into the front of the tube, at the botton. it is has a plastic covering on outside. Anyone kow what it is, because it is leaking gas. Please help ASAP.
Thanks
Old Jul 14, 2012 | 02:44 PM
myyota's Avatar
The part your talking about is called a fuel pulse damper. The reason it starts leaking is because under the plastic cover is a very small screw with a rubber o-ring, that screw can come loose and fall out and cause a gas leak.
You need to remove the pulse damper and pop off the plastic cover, if your lucky the screw will still be there and you can screw it back in and reinstall the damper. When you unscrew the pulse damper there is a copper o-ring, don`t lose it. If the screw is missing you will need to replace the pulse damper. A new one is about $80.00 dollars,
When I had this problem on my 86 4Runner I had to replace the pulse damper because the plastic cap and screw were gone. I bought a used damper and I checked to make sure the screw was in place and I put a little JB Weld around the screw to make sure it wouldn`t ever come out.
Old Jul 14, 2012 | 03:57 PM
dw1031's Avatar
My husband said the screw was in this one, but it looked rusty. He will pull it out to see if the o-ring is cracked or loose. Thanks for the reply. If this don't work, I can get one from Autozone for around $65.00. hopefully.
Thanks
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
raptor510
Feb 17, 2017 07:11 AM
_Nicco_
Aug 28, 2015 07:26 PM
jjrbus
Jul 27, 2015 11:06 PM
