Sponsored by: CARiD
Trying to drop A/T pan...
Old Aug 13, 2012 | 07:04 PM
Celtica's Avatar
Hi all, I actually joined here a couple of years ago, but I hardly ever post so I had to start over after my username became invalid... Anyway, I loosened the sway bar and removed the bolts after draining the fluid, but the dip stick part that you pour fluid down into is still attached and I don't know how to get it off so I can slip the pan off. The repair manual didn't even mention that part. Please help, thanks in advance..
Old Aug 13, 2012 | 07:11 PM
rworegon's Avatar
There is a bolt (nut?) that attaches the upper portion of the dip stick tube to the block...remove bolt. Now, give the tube a firm tug and it will separate from the lower tube. The lower tube is brazed to the pan so be careful that you don't bend or torque the tube.
You'll need a new o-ring at the joint where the tubes slip together.
http://www.utoyot8.com/Picture.aspx?...ccode=&ppName=
http://www.toyotapartseast.com/Page_...3497,3508,3515
Old Aug 13, 2012 | 07:26 PM
Celtica's Avatar
http://www.utoyot8.com/Picture.aspx?ccId=286530454&ppId=275081257&ppInfo= (8808-++++)4FC&ccode=&ppName=
Thank you SOOO much ! I'm going to try it tomorrow when it's light out again !
Old Aug 13, 2012 | 07:34 PM
rworegon's Avatar
When you separate the upper from the lower tube, use a hand on each side of the joint so things don't bend/
Old Aug 14, 2012 | 07:34 PM
Celtica's Avatar
So I got it off and changed the filter and now I need to know if there is a way to get the pan gasket to seal on or do I try to torque the pan down while trying to keep the gasket from flopping all over the place much to my frustration ?
Old Aug 15, 2012 | 12:38 AM
Vang530's Avatar
Use some RTV to help make the gasket stick in place.
buckz6319
Aug 5, 2017 03:50 AM
RDubya
Feb 10, 2017 04:46 PM
shredder4286
Oct 1, 2015 01:09 PM
bradahman
Oct 1, 2015 09:24 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
