Sponsored by: CARiD
bumpy ride = oil pressure light
Old Aug 20, 2012 | 06:38 PM
dholbrook's Avatar
'89 22re engine. I was having oil pressure issues meaning that when the engine was on my pressure light was on (cold/hot etc.). I checked wire and yes it has a couple splices, but still had continuity, so I bought a oil pressure diagnostic gauge to check pressure. Pressure seemed fine. Cold idle was about 75psi and warmed up idle was about 20. I figured my sending unit was malfunctioning, so i bought a new one. Now, every bump in the road lights my dash light. I figure it's an electrical problem, but aside from continuity from sending unit to wiring loom, what do I test/check?? Thanks in advance!
Old Aug 20, 2012 | 07:18 PM
rworegon's Avatar
Ground wires?
Old Aug 20, 2012 | 07:24 PM
dholbrook's Avatar
Yes well they don't call me a newbie for nothing, which/where/how do I check ground wires?
Old Aug 20, 2012 | 07:34 PM
rworegon's Avatar
https://www.yotatech.com/forums/f116...-guide-194413/
Be sure there is no corrosion on them and they are fastened tightly to clean metal.
Also, check under the dash and around the ECU and be sure those ground wires, if present, are tight.
Old Aug 20, 2012 | 07:36 PM
dholbrook's Avatar
OMG I love pictures, thanks for the link!!!
Old Aug 31, 2012 | 06:47 PM
dholbrook's Avatar
Ok so I checked my engine grounds and all look good and tight and unfooled around with.
Even with the sending unit unplugged it still flickers on vibrations and bumps.
Is it possible I could route a new wire to the ecu or gauge cluster? What would be the easiest way to do so?
THANKS!
Old Sep 1, 2012 | 12:29 AM
wyoming9's Avatar
Red face
Is it possible you have a loose connection where the wire attaches to the sending unit??
If I remember the light will come on when the circuit is grounded.
The easy fix might be to install a manual gauge.:wabbit2:
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Sep 4, 2015 09:27 AM
88yodabasket
Jul 13, 2015 01:32 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
