Sponsored by: CARiD
22re valve adjustment
Old Aug 13, 2012 | 03:59 PM
Dutter's Avatar
So the smog shop guy said i need a valve adjustment cus its running rough and is in the high 300s in carbon. And it sounds like i need to do it warm or hot is that true, and i need to know the specs and were to put my cylinders when i do the adjustment, and any tips would be nice thanks
Old Aug 13, 2012 | 05:51 PM
toyota4x4907's Avatar
Bring engine to operating temp (driving regularly for 10-15 minutes)
Shut it off.
Remove valve cover.
Remove spark plugs (makes this a lot easier)
With a 19mm or 3/4" socket on a socket wrench, turn the crank so the #1 piston is at TDC on the compression stroke. The timing mark on the crank pulley should be at "0". Both of the #1 (closest to the front) valve rockers should be loose. If they are not, turn it the crank 360* so they are.
With a 12mm BOXED END wrench, a flat-head screw driver and a feeler gauge with .008" and .012", adjust the #1 and #2 INTAKE valves to .008" or slightly tighter. Then adjust the #1 and#3 exhaust valve to .012, or slightly tighter. Using the boxed end wrench, just loosen the lock nut enough so you can turn the little screw in it. Adjust to the proper spec, then tighten it. It helps to keep a hand on the wrench on the lock-nut.
After adjusting those 4 valves, turn the crank 360* so the #2 exhaust, #3 intake and both #4 valves are loose. Repeat adjusting procedure, put everything back together. Done.
Old Aug 13, 2012 | 07:58 PM
Dutter's Avatar
alright thanks, ill geterdone in the morning
Old Aug 13, 2012 | 08:08 PM
GIT-R-DONE!
Old Aug 14, 2012 | 06:14 PM
Dutter's Avatar
well all of the valves needed adjusting so i adjusted them but now i hear a tinny ticking do yota motors hav a natural knocking sound, its not bad but i sounds like a quite diesel
Old Aug 14, 2012 | 06:24 PM
22RE4WD's Avatar
I still get a ticking noise at idle. Not as loud as before the valve adjustment though.
Old Aug 15, 2012 | 08:02 PM
Rinker's Avatar
So, do we have to live with the ticking, or is there a method of dealing with this? Would slightly tighter help this? Thanks.
Old Aug 15, 2012 | 08:10 PM
22RE4WD's Avatar
I've heard some people adjusting intake to 0.07 and exhaust to 0.11 to eliminate tick.
Old Aug 15, 2012 | 08:21 PM
These motors naturally tick. Yes, people have often tightened them to .007 and .011 with success, thats why I said "slightly tighter".
Old Aug 15, 2012 | 09:26 PM
Dutter's Avatar
yeah it was bad so i rechecked them and found a loos one and tighten it and now its real little, but it sounds like its normal i just wanted to make sure and the .007 and .011 are when the motors cold hot is 8 and 12
Old Aug 15, 2012 | 09:31 PM
Always adjust them when hot.
Old Aug 15, 2012 | 09:50 PM
Dutter's Avatar
just wondering but whats the theory behind that cus cant u adjust them to a different spec when cold
montanatruck
Feb 26, 2017 07:07 AM
coleypull15
Nov 3, 2015 07:41 AM
Sep 4, 2015 09:27 AM
razorman8669
Jul 12, 2015 12:13 PM
Gamble_STi
Jul 7, 2015 07:54 PM
