Sponsored by: CARiD
Is it Possible to Convert a W56 Transmission
Old Sep 5, 2012 | 07:53 AM
junk4u's Avatar
I kind of know the answer to this question, but I figured I would ask and hope that someone that has done it before and maybe get some good hints.
I was wondering if a W56 Forward transmission can be convert to a Top Shift Transmission.
I have the following:
1) Top shift Tail Housing case
2) Shifter rail(s)
I am looking at a W56 Forward transmission that is reasonably priced.
If anyone has done it before or has some sort of instructions please post.
Thanks
Old Sep 11, 2012 | 11:29 AM
junk4u's Avatar
Okay I'm guessing no one needs to convert there trannys because they have a bunch of both versions around them.
Anyhow, I believe I no longer need to do this, but since I researched the internals of a tranny and kind of figured it out, I'll just go ahead and post it here.
1) First thing would be to remove the Shifter and Shift rails from your old top shifter. This picture below shows the necessary item(s) needed to be removed from your old transmission (top shifter) in red.
Then you will need to remove the tail housing from the new to you forward case. and shifter(s) and rails.
Once you have that all off, Go over to the Forward and pretty much remove the same thing including the rails for the t-case which will no longer be required. Install the shifter rail and Tail Housing that you removed from your original top shifter and bolt it together.
If I am missing something or made some sort of error, please feel free to correct me since my knowledge of trannys is very small and I will soon have to make this conversion.
Old Sep 11, 2012 | 11:46 AM
waskillywabbit's Avatar
This has been done for a long time.
:wabbit2:
Old Sep 11, 2012 | 11:56 AM
junk4u's Avatar
:wabbit2:
Yeah I know that, but no one never gives details or answered any of the question about it and since 'm not to familiar with tranny's I just wanted to know. In any case thanks.
Old Sep 21, 2014 | 02:24 PM
Erick561's Avatar
From: I ship from New London Connecticut I PriceMatch
So basically if someone has enough motivation, then they will buy the forward shift tranny i have and use their blown top shift to convert it? ;-)
Old Sep 23, 2014 | 06:44 AM
junk4u's Avatar
Yup that would be the what it takes if anyone wanted too. Very easy and simple, I just got 3 trannys out of the scrap yard 2 of them top shifters and the other forward shifter. I purchased a forward shifter way back knowing that the guts were fubar so that casing I'm going to swap out when I rebuild it.
crammit442
7
Nov 29, 2017 12:30 PM
mskalmus
May 28, 2017 07:51 AM
JAmdor3
Aug 11, 2015 10:53 AM
89hilux1
Jul 19, 2015 01:32 AM
crashburnoveride
Jul 10, 2015 06:39 AM
