Sponsored by: CARiD
HELP! Stalls in 4WD mode.
Old Sep 18, 2012 | 06:51 PM
22RE4WD's Avatar
Hey Yotatech!
I was driving around the neighborhood testing out the 4WD mode. When shifting from 2H to 4H the dash indicates that 4WD mode is on. But when I drive from a stop, the car feels like it has a "load" on it, the back end squats and basically stalls the motor. I can hear one of the wheels lock up like it's dragging itself.
I remember when inspecting the vacuum lines, the previous owner crossed the line between the EGR and the VSV for the 4WD mode. Do you think this is a bad VSV or actuator? Or something messed up with the transfer case/differentials?
The vehicle is a 1991 4Runner 5 speed 22RE. Thanks guys for your help. Hopefully it's not an expensive fix.
Old Sep 18, 2012 | 07:05 PM
thefishguy77's Avatar
When you say back end squats does it feel like the back end is pushing faster than the front is pulling? I don't know a lot but could it be different gear ratios. Just a thought. If it has manual locking hubs have you tried unlocking them and driving it with the front end disengaged?
Old Sep 18, 2012 | 07:14 PM
22RE4WD's Avatar
You know what....i think you're right! The previous owner gave me a brand new set of Motive Gears for the front.
Would the 4WD engage if the vsv vacuum lines are not hooked up correctly and the indicator light doesn't come on?
Old Sep 18, 2012 | 07:17 PM
That's a question I can not answer. But I hope I helped
Old Sep 18, 2012 | 08:05 PM
westjohns yota's Avatar
if the vsv is not working then your dont have any vaccum to the front diff therfore your 4wd is not pulling
kawazx636
Oct 6, 2021 03:03 PM
tylermx71
Sep 29, 2015 08:49 PM
Cycles
Sep 29, 2015 06:37 AM
charlie_fong
Sep 27, 2015 10:06 PM
taraf
Sep 25, 2015 02:57 PM
