Sponsored by: CARiD
brake problem
Old Sep 5, 2012 | 06:55 PM
kelvinb's Avatar
brake problem
currently having some brake problems and would appreciate some assistance. I ordered new pads for my 22re 1989 4runner, and noticed the pads i purchased (mkd410) are to big for the caliper. i compared the pads i bought to the pads on the runner, and the pins are spread further apart and shims are not wide enough to fit. the caliper says s12+8 on the side, and after some reading noticed that it could be for an older toyota truck. i searched from 1983 trucks as well as the 1984-88 4runner v6/22re and they all come up with the same brake pad part number. please help!
Old Sep 5, 2012 | 06:57 PM
kelvinb's Avatar
maybe i didnt look for an older enough model. i found a different part number for an 81 4x4 truck.
BrakeBest®
Disc Brake Pads
Part # D137
Old Sep 5, 2012 | 07:21 PM
rokblok's Avatar
Sounds like you have the correct calipers for your 4cyl truck. One small piston and one large piston on each side of the caliper. But it sounds like maybe they gave you V6 caliper pads. (For vehicles equipped with the V6). Those calipers have four larger pistons in each caliper. (also a popular upgrade for 4cyl trucks, do a search if you've not heard of it.).
Maybe exchange the pads for '86-'87 pickup era? No V6 was available then so maybe the parts person will have less options. Just a thought anyway...
Old Sep 5, 2012 | 07:39 PM
kelvinb's Avatar
Does the v6 have the s12+8 calibers?
Old Sep 5, 2012 | 07:57 PM
rokblok's Avatar
I don't remember what the V6 calipers have cast on them. Although they do have many cooling fins and are much bulkier compared to the no cooling fins and plain casting of the 4cyl caliper. I will check my old 4cyl calipers tomorrow and try and report back.
Old Sep 6, 2012 | 07:30 AM
kelvinb's Avatar
heres a picture of the new pad under the old pad. the old pad is offset to the right so you can see the hole lined up, and you can see that the new pad is longer and the pins do not line up. part number for the new pad is MKD410
Old Sep 6, 2012 | 08:30 AM
kelvinb's Avatar
after some more research this is what comes up. fyi it is a vented rotor
TOYOTA TRUCK
8173/8174 95 ALL S12WE
4 Runner
8171/8172 95-91 ALL S13WB
8169/8170 91-88 ALL S12W R/L
4407/4408 87-84 ALL (4 Cyl) S12-8
Landcruiser
1478/1479 92-91 ALL S13WA
4407/4408 90-75 ALL S12-8
TOYOTA TRUCK
Pickup, Hi-Lux
8171/8172 95-91 T100 Pickup 4WD 1/2 Ton S13WB
2011/2012 95-89 2WD 4 Cyl. l 17S R/L
1242/1243 95-89 DRW AISIN 1 R/L
8567/8568 91-89 Long Bed F18Q R/L
514/515 91-8/83 2WD, 1/2 Ton AISIN
4407/4408 88-86 Long Bed 4WD W/4 Cyl. S12-8
4409/4410 85-80 Long Bed 4WD S12+8
and this post says
Front
1996-2001 W/ 16” Wheels............................................ ............ S13WM 1830 1831
1996-2001 W/ 15” Wheels............................................ ............. S12WE 1828 1829
1992-1995 .................................................. ............................ S13WB 1601 1600
1989-1991 From 4/89................................................ .................. S12W 1241 1240
1988-1989 W/ 4 Cyl. Before 4/89................................................ . S12+8 827 826
1988-1989 W/ 6 Cyl. Before 4/89................................................ . S12W 1241 1240
1986-1987 Vented Rotor............................................. ................ S12+8 827 826
1984-1985 Solid Rotor............................................. ................... S12+8 821 820
Old Sep 6, 2012 | 03:52 PM
rokblok's Avatar
I have an '84 x-tra cab, 4wd shortbed. I pulled off S12+8 front calipers when I did my V6 caliper/FJ rotor upgrade. Solid rotors.
Old Sep 6, 2012 | 07:11 PM
kelvinb's Avatar
vented rotors for mine. i got that part number (d137/mkd137) and it was correct. it was listed on the box 85+ trucks. problem solved.
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
skoti89
Sep 11, 2015 07:46 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Jnkml
Jul 6, 2015 01:20 PM
