Sponsored by: CARiD
Tried to raise my idle and nothing happened
Old Jul 31, 2012 | 07:34 PM
Dutter's Avatar
Hey i just got my first yota its got the 22re on 33s 4x4 of course and its a 91, And im use to fords and chevys so ill be one this site alot. But my brother tried to raise my idol with the flat head screw and nothing happened, dos this mean i have a leak in the pile of hoses and will that effect smog
Old Jul 31, 2012 | 07:45 PM
dropzone's Avatar
Fossilized
Welcome to yotatech. We have a bunch of knowledgeable members.
Here is a link to where u can down load the factory service manual
http://ncttora.com/fsm/index.html
Old Jul 31, 2012 | 08:11 PM
Dutter's Avatar
Thanks,, yeah i couldnt find a 91 pickup in there,, there was a 93
Old Jul 31, 2012 | 08:23 PM
4Crawler's Avatar
For the most part, 22RE = 22RE, so a '93 22RE is the same as a '91 22RE.
Old Aug 1, 2012 | 10:13 AM
Dutter's Avatar
oh duh, guess i wasnt thinking, and alost do i have a speedo cable or is it electronic mine went out
Old Aug 1, 2012 | 10:22 AM
4Crawler's Avatar
Easy enough to look at the back of the t-case (passenger side). If you see a cable:
That is what you have, if you see a couple of wires plugged into a speedo sender, then you have electronic.
Old Aug 1, 2012 | 03:32 PM
Dutter's Avatar
yep it was cable, thanks
Old Aug 1, 2012 | 07:21 PM
Dutter's Avatar
oh one other thing,, were do theyy usually break and can i just replace the cable
Old Aug 1, 2012 | 08:12 PM
4Crawler's Avatar
Probably pull the cable and see if the drive gear is intact and attached. If so, you could try spinning up the cable and see if it spins up at the speedo end, or run it with an electric drill and see if the speedo needle moves. If not, the cable may have snapped and you need to replace it.
Old Aug 1, 2012 | 09:57 PM
Dutter's Avatar
alrightty ill check that out tomorrow
Old Aug 7, 2012 | 04:08 PM
Dutter's Avatar
well i took it off and tried to spin it and it wouldnt spin its just twist the stop,, what do i do from here
Old Aug 7, 2012 | 04:18 PM
4Crawler's Avatar
Guess it depends on which end you took off and spun. If it was at the t-case end, then that says something in the cable up to the speedo is sticking. Could be the cable has snapped and the broken end is stuck in the housing and not letting it spin. Or it could be the speedo itself seized, you could check that by disconnecting the cable on the back of the speedo and see if it'll spin with both ends loose. If not, cable is toast, if so, speedo is toast.
Old Aug 7, 2012 | 04:33 PM
Dutter's Avatar
alright will do thanks
Old Aug 7, 2012 | 05:17 PM
Dutter's Avatar
yep cables broke, i twisted it harder and it all slide out
smthwsn357
May 1, 2024 07:28 AM
shisha1999
Sep 21, 2015 08:22 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
toyocruise
Aug 6, 2015 04:43 PM
shisha1999
Jul 13, 2015 11:09 PM
