Sponsored by: CARiD
Need help with gauges
Old Jul 27, 2012 | 07:51 AM
claybrook's Avatar
Question Need help with gauges
I got the water temp and oil pressure gauges. I cant find anything to fit oil pressure gauge. How did yall wire it up?
Old Jul 29, 2012 | 09:43 AM
83's Avatar
83
What exactly do you mean? Like the oil pressure sending unit? Or actual wires, or what?
If you've got idiot lights, then you've got an oil pressure...can't remember the name. There are two kinds. One is for the idiot light, and one is for an actual gauge. If you hook the idiot light switch up to a gauge, you run a very real risk of frying your gauge. They're two different plugs. One I think is an oil switch, the other a sending unit. Switch for idiot light, sending unit for gauge.
The switch and sending unit thread into the oil galleys in the engine block. There are some threaded plugs with a hex pattern in them, in a couple locations on the block. Intake side seems to be where the oil switch/sending units are usually threaded in. You'd just want to drain your oil, take out the plug, screw in the sending unit.
Old Jul 29, 2012 | 11:05 AM
westjohns yota's Avatar
zach you keep beating me to these posts -.- what he said! ^
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
zanzabar0
Oct 11, 2015 02:56 AM
Jdgarrison
Oct 1, 2015 05:22 PM
dbollier123
Sep 29, 2015 05:23 PM
