PDA
View Full Version : Newbie Tech Section
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
  1. Low Idle / Pulsing Idle 95 4runner 3.0
  2. Brakes
  3. Hard Start and Hesitation
  4. Sas
  5. 1991 v6 3.0 xtra cab payload increase? or new truck?
  6. Cant Figure Out What This Part Is
  7. Source for OE Parts
  8. 2018 4Runner
  9. New camshaft and rocker arms
  10. G52 swap
  11. Should I Still Try and Drive this Thing?
  12. Trying to decide how to go about this!
  13. 88 4runner 4x4 v6 3.0l
  14. Flooding
  15. Where does this vacuum line go?
  16. Weber 36/32 Leak
  17. 1991 TOYOTA pickup 22re WARM/hot start issue
  18. 1985 2wd base Newbie build suggestions
  19. Timing Chain Disaster
  20. Stubborn fuel line fitting
  21. Another 4.3 swap question
  22. 88' 4runner timing chain
  23. Aftermarket temp gauge
  24. Starter Problems
  25. 95 4Runner A340H Solenoids
  26. Whining noise after front main seal and drive belt replacement
  27. Adding automatic transmission fluid
  28. Sas question
  29. 22re wont start
  30. 93 toyota pickup 4x4 problem
  31. tacoma 4wd wont engage
  32. three prong coolant temp sensor
  33. Oil overfill question
  34. update
  35. Change gear ratio on dually 1 ton toyo axle??
  36. A bit lost
  37. One cam moved during timing belt job.
  38. How do I get rid of the seatbelt buzzer?
  39. new head unit
  40. Most reliable truck
  41. 93 4runner 3.0l trouble code 25 engine lean mixture
  42. 1986 Pickup/1999 4runner Parts Compatibility
  43. 00 2.7L Exhaust leak & Loss of power - HELP!
  44. Which way to turn distributor to adjust timing?
  45. 87 Ac Help
  46. Vcs
  47. 1990 3.0 3vze Limp mode ? Jump Time ? Ideas ?
  48. 5vz fe wiring harness
  49. 1994 Pickup Problems
  50. Clicking/knocking noise from valve cover
  51. what yota to get the comparison of many greats
  52. wheel interchange
  53. 88 Toyota single cab camper shell
  54. 88 Toyota single cab camper shell
  55. 99 runner died but started right back up
  56. 92 Land Cruiser wobbly fan, threw fan belt
  57. Hunting a part name/number
  58. Truck is running rich
  59. 3VZE Opened Radiator/Disconnected Intake Manifold
  60. Tundra brakes on an 05' Taco
  61. 92 Land Cruiser wobbly fan, threw fan belt
  62. Webber 32\36 with Ac
  63. factory service manual 1999 4 runner
  64. Con rod order - 22R
  65. Engine swap7
  66. 2007 4Runner died while driving and restarted no problem
  67. 22r ignition
  68. RATS RATS everywhere there was a wire
  69. rear end
  70. Expert 4th generation toyota trucks, Auto Trans, Weber Carb
  71. 1987 Toyota Pickup Temperature questions
  72. 1987 Toyota Pickup Overdrive light questions
  73. 22r carb parts where?
  74. Need help, advice, a point to the right direction
  75. 93 3.0 engine trouble
  76. What is the cylinder head bolt removal pattern for a 92 22re
  77. 1986 toyoya 22r 4x4
  78. MAF gate does not open
  79. oil dipstick location
  80. 85 Toyota SR5
  81. new engine wont run, throwing code 11?
  82. part throttle power loss after engine warms up
  83. Missing, Knock CEL, Hesitation ~1800-2400RPM
  84. 1982 Beige/Black interior colors
  85. front end locker
  86. 22re intake installation
  87. 86 22rte coolant line question
  88. 89 Toyota Pick up - No fifth Gear or reverse
  89. Truck not starting - Clutch sensor maybe?
  90. Tranny pan?
  91. Auto to standard
  92. Center Caps
  93. 1993 Toyota Pickup V6 5 speed manual
  94. Help me understand my new 2002 Limited, 4wd/2wd/AWD options and when to use them
  95. Body work noob needs help
  96. Speedo highly off on 2nd gen 4Runner
  97. mechanical fuel pump delete questions .
  98. New Toyota Pickup
  99. 3.0 won't idle after timing adjustment
  100. engine swap
  101. Requirements for an A/C pump
  102. Rough Ride 2002 4Runner
  103. Missing
  104. 1991 toyota pickup DLX
  105. New to the forum
  106. Off the Wall Question: Swap 3.0 for a 22RE
  107. 22re cylinder head will not even budge
  108. Help me understand my new 2002 Limited, 4wd/2wd/AWD options and when to use them
  109. T100 Leaf Springs - normal?
  110. Engine light/rough idle and under load.
  111. Oil gauge
  112. Stock cluster swap to sr5 cluster
  113. Drop front dif and oil pan for timing?
  114. 94 hilux miss
  115. Is there suppose to be Fluid in Coil/Igniter??
  116. Diff Slop
  117. Transfer case help.
  118. Gearing
  119. Incredible popping from underside of my truck
  120. 86 single cab 4x4 , to 84 extra cab body ?
  121. Engine sputters, truck jerks 3000+ rpm
  122. 2005 Tundra grind
  123. Can I drop an 88 long block in my 94 and swap in my 94 components?
  124. Leafsprings from 4Runner fit 1st Gen truck?
  125. Rattle sound under load 22re
  126. spark just quit
  127. 1986 toyota 22re engine code 6 and 12
  128. 3.4 Swap wont start
  129. Inner tie rod rubbing frame after replacement
  130. 2005 doublecab sr5 tundra 4x4 issue
  131. 93 22RE RC Pickup - Overheating/Idle Issue
  132. Running lights staying on
  133. Motor mounts
  134. Heater hose routing
  135. Fuel Distribution Problems
  136. #1 misfire is driving me crazy.
  137. 92 Toyota 22re idle up vavle
  138. Backfires, stalls, spits and sputters
  139. New Water Pump?
  140. Cracked block or head?
  141. Maintenance Tool Kit for a Beginner
  142. 92 3vze bad buy 😭
  143. 22r off to machinist - HELP
  144. 3.4L Engine noises
  145. Fuel pump relay..?
  146. Head gasket help for 82 22 r
  147. 1982 22r wont idle when warm
  148. Potential buyer/ general questions
  149. axle strength
  150. 95 4runner fuel economy
  151. 95 4runner oil pan low point is stupid
  152. 2015 4Runner rebuilder .. flashing 4wd light...
  153. Help with advice on tires. (I'm sure this is asked a lot)
  154. Trans questions
  155. New to Toyota Pickup Pricing?
  156. 22re issues
  157. Power steering leak help
  158. 93 Pickup, 22RE, RC, 5SP, ~225k Miles - Distributor Cap/Valve Cover Gasket
  159. w56 od gearing questions/ fuel mileage
  160. reverse camera
  161. Looking at truck bad clutch
  162. New engine oil recommendations
  163. 95 4Runner warped heads and piston hole
  164. 4WD Tansfer Case Shifter Position
  165. Code 52 dead end
  166. 98 vtec motor
  167. 98 - 4 Runner Head relay Switch Noise?
  168. Wiring for trailer
  169. Alternator wiring confusion
  170. Engine retailers?
  171. 2006 Tacoma rear squeak
  172. Which transmission do I use?
  173. Failed ca smog at 15mph. Really high NO and barely above max HC
  174. Electrical issue
  175. Suspension differences between 4runner and P/U
  176. 85 4Runner Rear Window Fix ish...
  177. 1991 4runner 3.0 no spark at coil
  178. FJ60 and 80 general questions
  179. I think I destroyed my rear end
  180. Oil Leak, 3.4L V6 Front of Engine. Developed Quickly
  181. Hard cold start 2.7l Tacoma Please help
  182. Charging system, and alarm problem
  183. New owner '95 4Runner: power upgrade?
  184. found this best octane booster online
  185. High idle and open loop
  186. no help / 3.0 3rd Gen. 95 pickup
  187. Correct Mileage
  188. 1990 Toyota Pickup DLX Surging Issue
  189. 94 Previa no start after heavy rain high humidity
  190. Throttle issue..? Please help
  191. need to replace shockabsorber?
  192. Spindle and spindle nut thread
  193. 92 Toyota pickup 2" or 4"
  194. '98 4Runner Lean Code please help
  195. '98 4Runner Lean Code please help
  196. Clutch Issue
  197. Noise and vibration when hubs are locked 2wd and 4wd
  198. 33" tires with 3" lift
  199. When to fix an oil leak
  200. When to fix an oil leak
  201. What is this thing
  202. 1993 4RUNNER keeps blowing 10 amp AC Fuse
  203. 01 Sequoia 4WD Issues
  204. Replaced h2o pump-won't turn over
  205. Replaced h2o pump-won't turn over
  206. DIY tonneau
  207. Transfer case shifter sheet
  208. I have a 2013 Tecoma TRD off road with 4.0 motor
  209. Clutch issue?
  210. Low oil psi
  211. cam & timing chain install question
  212. Temp spike from coolant leak
  213. 88 22RE limited throttle in wet conditions/sputtering
  214. Stiff gas pedal
  215. High idle...constant...charge light and e brake light came on at the same time
  216. I have no check engine light. 1990 22R pickup
  217. 1986 dlx cluster to 86/87 22ret analog gauge cluster
  218. Need help buying first truck
  219. 3vze Mechanic Saint Louis, MO
  220. 8822REC timing
  221. Crankshaft bolt removal - bump start
  222. lift options for my 1992 4wd ext cab sr5 w/3.0 v6
  223. 97 Tacoma Vibrates in 4wd
  224. r150f transmission
  225. 85 toyota celica st 22re
  226. p1300 96 t100 newbiest of newbs
  227. What are the symptoms of "vapor lock?"
  228. Front Diff Seal (Couldn't find an answer through search)
  229. Mis Matched gears in a 92 Runner
  230. Tires? Size?
  231. 1993 Pickup Idle Up Screw Missing (A/C and power steering)
  232. 22R Extreme High Idle When Started
  233. Ticking TC time bomb...
  234. 2wd -4wd frame swap
  235. damper removal on truck
  236. best differential for 4runner 1995
  237. Power steering leaking onto alternator 22re
  238. 94 22re valve cover gasket
  239. Gear ratio
  240. transmission identification
  241. 1990 Toyota 2wd 4 speed Clutch
  242. 38 dgas vs 32/36 weber carb
  243. Cable rear locker
  244. 4WD light not turning on after engine repair
  245. possible purchase!! need help!!!
  246. snorkel
  247. 3.4l swap question
  248. Heater issues 99 4runner
  249. I have no idea what I'm doing
  250. how to mount light bar on roof 88 4runner
