Sponsored by: CARiD
Which way to turn distributor to adjust timing?
Old Jun 17, 2017 | 10:45 AM
Ldopamine's Avatar
Which way retards timing in the Nissan Quest/Mercury Villager V6 3.0 Clockwise or CCW?
Old Jun 17, 2017 | 12:11 PM
millball's Avatar
I don't know. I can tell you that if you crank the engine a bit with the dist cap off, you can see which direction the rotor turns.
If you move the dist. in that same direction, you will retard the timing. If you move the dist. against the rotor rotation, you will advance the timing.
This holds true for all engines, and makers.
Old Jul 14, 2017 | 09:02 AM
Iperea's Avatar
Youtube has some good videos that will help you!
hidesert
24
Jul 5, 2024 03:51 PM
c121
Jun 15, 2017 03:03 PM
jhsantacruz63
Jun 15, 2017 06:48 AM
Tomalex92
Jun 13, 2017 08:09 PM
myotherrideisayoshi
Jun 12, 2017 09:04 PM
