Sponsored by: CARiD
Need help, advice, a point to the right direction
Old May 15, 2017 | 05:47 PM
jeraldcunanan's Avatar
I don't know if allowed to post or if in the correct place, but I need help....read numerous and helpful posts, and threads...still need help..... thanks in advance for any help, info, suggestions, and/or advice.
1994 Toyota T100
M/T 5 spd 4x4
6 cylinder
3VZE
M/T no cruise control....i put a spring to hold it here.
Can't find a pic or diagram to show me where these wires go.....
is this oil temp sensor or a different sensor ?
TVV (broken) correct ?
Does that sensor or switch have something to do with 4x4 ?
what valve is this ? what wires or vacuum hose(s) go to it ?
bottom hose of charcoal canister, does it connect to a hose that goes back to fuel tank ?
Old May 25, 2017 | 01:07 PM
75w90mantraN's Avatar
On pic #3, that's the oil pressure sensor.
On pic#6, I shot a diagram from my Haynes...somewhat to mostly accurate...it seems that the hose is connected differently. If your EVAP system is giving you codes, perhaps re-route and see...
Hopefully other members can help you out. Haven't dealt with EVAP systems as much or the 3.0 engine though it should be similar to the 3.4. Try looking/searching the forums for your specific Toy.
Attached Thumbnails Need help, advice, a point to the right direction-wp_20170525_001.jpg
Old May 26, 2017 | 05:15 PM
Thank you for reply I will re route and observe if any changes.....
Old May 31, 2017 | 02:12 PM
wyoming9's Avatar
Red face
You sure have a mess I am hoping you just bought this.
Sad when things get neglected
Your best bet is to track down a copy of the Factory service manual for your year.
Find some Toyota addicts around where you live.
If you were close i would be glad to help
Old Jun 1, 2017 | 02:15 PM
Yea it is a mess lol....got it a few months ago and once i had time to check / inspect i keep finding more things that do not seem right... thanks for response
