Sponsored by: CARiD
Running lights staying on
Old Mar 21, 2017 | 07:54 PM
bigelk's Avatar
My 99 4runner has a mind of its own some days , The running light will stay on some days and other days they go out , Would any off yous know what the issue is ...
Old Mar 21, 2017 | 09:37 PM
RAD4Runner's Avatar
Stay on when you want them on, or stay on when you try to turn them off?
Got multi-meter?
Old Mar 22, 2017 | 06:38 PM
bigelk's Avatar
When i shut it off the Parking lights stay on ...
Old Mar 22, 2017 | 07:21 PM
MrShocker's Avatar
Possibly corrosion or something going on with the switch...
Old Mar 22, 2017 | 07:54 PM
bigelk's Avatar
Awesome thanks i will look into that
Old Mar 23, 2017 | 08:13 AM
MrShocker's Avatar
Check and test your park lamp relay as well.
Old Mar 23, 2017 | 08:31 AM
RAD4Runner's Avatar
both of the above.
Nice if i had a multi-meter, and if u can post schematic of ur tail light circuit so we can point out where to probe.
Old Mar 23, 2017 | 04:02 PM
Co_94_PU's Avatar
99 is new enough to have the automatic cut offs. Simple fix and check is to use the switch, if they still fail to shut off you have a proper wiring issue and maybe not an issue with the integration box.
Old Apr 20, 2018 | 04:14 PM
gixxsta04's Avatar
Try changing the headlight switch?
