Sponsored by: CARiD
87 Ac Help
Old Jun 16, 2017 | 11:48 AM
darmentle's Avatar
87 Ac Help
Ac/Heater there not a lot of cool air coming out of the vents , replaced the resistor on the blower motor and it has the speeds just like something blocking the air from coming out or the blower motor is really week it. and sometimes it feels like there hot air coming out as well? truck has 362K miles on it. confused on also does the selector have to be set on Bi level or vent while the ac is on this is the style of HVAC controls i have.
http://www.ebay.com/itm/1984-1988-To...3D201353895175
Old Jun 16, 2017 | 12:20 PM
millball's Avatar
First thing, you need to confirm that the heat/vent controls are actually moving the air doors as intended.
Old Jun 16, 2017 | 12:31 PM
darmentle's Avatar
Can i do that buy removing the climate control controls?
Old Jun 16, 2017 | 12:39 PM
millball's Avatar
It might come to that, but first look behind the glove box at the heater/AC box and ducting, I'm pretty sure you can see the lower terminations of at least a couple of the air blend cables. You ought to be able to see if those door actuators move when you move the controls. You can also see if the heater temp cable moves the hot water valve on the firewall, under the hood. A factory service manual would be helpful to you.
Old Jun 16, 2017 | 12:41 PM
darmentle's Avatar
Thanks i will start there shot lube at the cables also
Old Jun 18, 2017 | 06:50 PM
darmentle's Avatar
so i removed the glove box and everything seems to be move the only one i cant see is the vent selector cable, blower seem fine, the cable the controls the temp from hot to cold was working at the bottom. what does bi level selector do?
