Sponsored by: CARiD
22re wont start
Old Jul 21, 2017 | 07:18 PM
Cliff Mundt's Avatar
22re wont start
85 TOYOTA SR5 - 89 22RE
Hey my brother came up to visit and his yota died, we replaced the motor, new head gasket, timing gasket, gaskets that had to come off to do the head and timing gaskets, spark plugs, rotor in distributor. But now that the motors installed we can smell gas tested spark but she just isnt firing, only cranks. Any ideas?
Old Jul 21, 2017 | 07:29 PM
L5wolvesf's Avatar
Timing / distributor off 180?
Old Jul 21, 2017 | 09:11 PM
distributor is good and sparks, were gonna pop it open again and check the timing position on the chain and gears. any other advice?
Old Jul 21, 2017 | 11:38 PM
wyoming9's Avatar
Red face
Just what sparks on the distributor ??
For a minute they I was thinking points
Old Jul 22, 2017 | 09:13 AM
L5wolvesf's Avatar
Is it trying to fire up at all or just turning?
Old Jul 22, 2017 | 10:55 AM
Its just turning
Old Jul 22, 2017 | 10:59 AM
Spark is good
Old Jul 22, 2017 | 11:49 AM
wyoming9's Avatar
Red face
Well if you have spark it can only be timing or fuel
Don`t forget the complete Air intake must be installed and tight,
Wires on Correct??
Did you destroy the injector harness when removing the harness when removing the engine
Those connections get quite brittle with old age.
Just because you smell fuel does not mean your injectors are firing.
Though you might have a fuel leak
Old Jul 26, 2017 | 10:30 AM
Wires on Correct??
Everything was hooked up proper, original motor oil was milky, replacement motor burning coolant out the exhaust after new gaskets... Sigh...
Old Jul 26, 2017 | 11:05 AM
L5wolvesf's Avatar
We're getting info in little bits and pieces. Was the head shaved before it was installed?
