PDA
View Full Version : Newbie Tech Section
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55
  1. Suspension questions
  2. Test for bad head gasket
  3. 2001 Sequoia - Roof rattling between 25-45mph
  4. How To Remove Front Grill
  5. idler arm and pittman arm replacement?
  6. tps
  7. Brackets, and pulleys, and pumps, oh my...
  8. driveshaft/ t-case shifter ???
  9. Driveshaft Removal / Approval
  10. 22r vs. 22re
  11. Back in the game.
  12. Ticking (lifters?) 95 4runner
  13. Another newbie question about rotors
  14. just another new guy...
  15. New headlights
  16. Older front clip fit newer body style?
  17. ????bumed???? bout 22r motor swap
  18. BAD hesitation/ power loss/ gas mileage - no check engine light/codes
  19. help...rattling under the hood?!
  20. High idle problem
  21. Cleaning & adjusting brakes
  22. 86 4runner wont turn over
  23. old 2.4 diesel the same as a jdm diesel
  24. Differential gears
  25. )* 4Runner
  26. 95 4Runner starts rough?
  27. 88 Auto small lift
  28. How to remove surface rust from a chrome bull bar.
  29. Newbie with questions
  30. transmisson swap
  31. where can i buy an aftermarket airfilter?
  32. Water crossing depth
  33. Engine noise
  34. Question? Help!
  35. F150 vs. Chevy springs
  36. Wabfab 2''
  37. hey guys from mas
  38. 22re no fuel
  39. Brake issues/ brake locking
  40. 84 22r wanna go frum injectoin to carb
  41. 1987 Pickup knocking noise
  42. what happens to the dry gas?
  43. a/t temp light flickers
  44. Injector advice!
  45. Do i have to go to the dealer?
  46. Tranny weight
  47. multi ground plugs?
  48. lifting the 3rd gen. ideas?
  49. Alternater help
  50. 1 QUICK rear leaf lift + hanger - question - 88 4runner
  51. wierd idle
  52. Please help
  53. What head do i have?
  54. Weld em' or Bolt em'?
  55. New U-Joints Don't feel right
  56. it just went SNAP!
  57. Master Cylinder problem?
  58. ever use this ?
  59. Stupid question but.....
  60. When ordering my 5.29 ring and pinion....
  61. Wanting to buy a 4runner...what to look for
  62. 22re various engine probs help!
  63. timg chain conversion 2 double row
  64. Power steering is moaning.
  65. To buy or not to buy?
  66. Multiple Warming Up Issues. BVSV?
  67. Running Lean, Vacuum Leak?
  68. timing chain replacement
  69. How to stop a cracked dash
  70. Not Starting! distributor or module??
  71. Mileage vs. Price
  72. Oil press. fluctuation. Why???
  73. Fuel rail hose
  74. remove hoses? name this part?
  75. 85 carb wont idle
  76. Please Help!86 runner :bang: :bang:
  77. K & N air filter
  78. good deal??
  79. 1991 4runner hub not locking
  80. New Owner of 3rd gen 4runner with a lot of questions (Really Long)
  81. 22rte Fuel Pump P/N
  82. Power Antenna Issue
  83. Rear heater
  84. Water up the exhaust...
  85. 1987 Transfer Case Help
  86. 22RE Radiator replacement
  87. same part diff. name??
  88. Help 86 4runner
  89. 87 4runner missing
  90. rear axles
  91. Tire size for 5" lift
  92. somebody please advise, PO750 code, Help
  93. Timing belt ?
  94. im a noob and need help with my 4runner
  95. Possible Birf Problem
  96. help with a light bar
  97. trying to start but no go
  98. 89 4runner can be jump started but dies soon after! Any Ideas?
  99. extra's needed when doing a lift besides the springs/spacers???
  100. striped camry head bolts
  101. '94 pickup power steering converstion
  102. 1997 4runner V6
  103. Yet Another 22re Idle Issue
  104. TRD Tundra springs?
  105. Question about buying truck
  106. 3vze no fuel issue???
  107. how hard is it to change a 86 2wd to a 4wd?
  108. Did 94-96 toyota come with v6
  109. WTF? is that noise
  110. these fender flares aren't factory are they?
  111. Setting Timing-why plug the vacuum lines?
  112. silicone the intake manifold gasket?
  113. Back Window For the 4Runners
  114. Someone Smashed My Window
  115. 1st time toyota owner...90 4runner tranny help
  116. 1991 3vze
  117. Radiator overflowing after driving on interstate
  118. I think my A340H is about to give up the ghost
  119. what is a JDM Toyota?
  120. One Locker(aussie)...Rear or Front.
  121. Running with no valve cover
  122. Heat and AC not working
  123. Newbee edwin4x4
  124. 22RE ring end gap
  125. 22re, trouble firing up
  126. Third member options (might be noobish)
  127. trans and transfer case ?
  128. need help!!!!!!
  129. grinding rear end
  130. 90 4runner v6 auto shuts down no warnings
  131. want to swap seats, need new dash pad
  132. Need To Replace Rear Shocks 2000 4 Runner
  133. When it comes to Brakes I need Help.
  134. '99 4runner tire rim combo
  135. Nice oil pan gasket for a 22RE?
  136. MityVac Brake Bleeder Kit
  137. Why is this loop on my truck?
  138. random parts
  139. Mud Flaps?
  140. New Here - Exhaust ?
  141. gears
  142. tranny swap question
  143. newb questions
  144. Fj40 distributor problems?
  145. bunch of questions about my 904runner.
  146. 1995 4Runner tire question
  147. adjusting brake pedal
  148. my '94 4runner running rough
  149. Locker question, among some other things
  150. axle and caliper swap
  151. 3rd gen TRD 4runners?
  152. 22r Cylinder Head Question
  153. Traction Control?
  154. 95 4runner Tire Question
  155. re-intexing torsion bars
  156. o2 sensor harness plug broke
  157. Will truck shocks fit 4runner
  158. Newb needs help getting started
  159. is this length safe?
  160. How can I do a quick check of my 95 4runner 3.0 timing belt?
  161. Taco camper shell issues
  162. Locker, Lockers or swampers?
  163. Proper rear main replacement
  164. Biggest tire i can use?
  165. 2nd gen ifs diff install
  166. Help!!! buying First Gen 4Runner
  167. Canopy Shopping - What size?
  168. check engine light
  169. Floor Jack and Jack Stands for Lift Install
  170. A340H OR A340F which one is it?
  171. A340H OR A340F which one is it?
  172. Will a 05 Tundra 4.7 engine fit in a 03 Tundra 4.7 truck?
  173. 33x13.50-15's will fit a stock toyota pickup
  174. 1st Gen 4Runner Trans Noise Help.
  175. 4run deisel not starting.
  176. Anybody do the KC Lights Windshield Bracket?
  177. Recall Info
  178. Parts truck ideas
  179. 1uz-fe
  180. get rid of smittybuilts??
  181. Hopefully my new toy
  182. motor swaps??
  183. Transfer Case Problems!!
  184. Timing w/o a Timing Light
  185. 95 4Runner engine knock sensor
  186. i am new to toyotas and am about to give up :(
  187. what do you prefer Taco, Tundra, 4runner??
  188. overheating....a little
  189. What timing light?
  190. Guess what I'm doing this week end?
  191. Weber 34/34 too rich
  192. Alternator issues
  193. truck not having all the power
  194. Can't get timing right
  195. new 4runner
  196. new here
  197. 87'-88' Shifter Swap
  198. i hate to ask but what is high pinion
  199. Gear Ratio
  200. "toyotafiberglass" replacement pannels, what do you think?
  201. Anyone Live In Rifle, Colorado
  202. Tacoma Prerunner lift on a 95 4Runner?
  203. newbie asks a clutch question
  204. Rear Window wiper problem?!
  205. Cant seem to find my jack or release my spare tire
  206. toyota pickup baja fenders
  207. Drive train stutter
  208. Hard start when warm?
  209. 85 4runner idles good dies when accelerated help?
  210. 2000 4Runner Coolant Problem....
  211. help wiring radio speakers
  212. hard/soft ride button and dealing with sag
  213. First Mods?
  214. Newbie/air in cooling system, head gasket?
  215. 1999 4runner
  216. Locker oh yes!
  217. There's coolant leaking, but from where?
  218. Headers for '82 Toyota Truck???
  219. 1988 4 runner lift advice
  220. 1988 4runner mods??
  221. add leaf or custom shocks? need advice
  222. Head swap, hesitation
  223. torsion bar bolt issues
  224. Data link connector Location ?????
  225. fuel pump problems
  226. recent rebuild, need help with some bugs
  227. O2 sensor - where is it
  228. Number 1 cylinder is DEAD!!!.
  229. LC engineering engine swap... Help!
  230. tacoma/4runner same parts?
  231. i fun a 4runner turbo...
  232. Brake pad install? (and more)
  233. 2.5" diameter enough for snorkel?
  234. Wheel paint sub?
  235. Newb rear end help
  236. New to your site looking to get good insight
  237. Newb needs a lot of help...
  238. where to get a cheap 87 4runner turbo?
  239. what's wrong with this 4runner?
  240. Which is better: cheapo component speakers or 3-way coaxials
  241. 3 rads?
  242. 33x12.5x15 on factory rim
  243. What is the minimum I need to have to go off road
  244. help!! 97 runner mod ideas?!
  245. 1991 Toyota 4runner Code 52 and engine "jerk"
  246. Thoughts on 3.4 vs 4.0 (the real one this time)
  247. front bumper replacement
  248. hate vacume
  249. 2002 2.7 engine questions
  250. QUestions about ruf swap
