Sponsored by: CARiD
How To Remove Front Grill
Old Jan 12, 2009 | 10:49 AM
Whiplash Willy's Avatar
I am trying to remove the front grill on my 93 toyota pickup 4x4, and can't figure how to get it off. I removed the corner lights, and undid all of the snaps on the top. I saw three on the bottom that I can't figure how to undo. Any suggestions on how to undo those? Also, is there anything I missed?
How do you put the snaps back in without breaking them?
Old Jan 12, 2009 | 11:24 AM
Gavy's Avatar
Well usually unless you are super careful one or more of the snaps will break at least I know I broke a few. You don't need them all to hold it on however. As far as removing it I can't quite remember how many snaps were on the bottom but even when those were undone on mine I had to coax it alil bit by wiggling it and it eventually came off no problem. I used a flat blade long handled screw driver to push the tabs in on the underneath ones while at the same time pushing out on the grill so they would release.
Old Jan 16, 2009 | 09:53 AM
Ron Helmuth's Avatar
have a helper exerting some pressure pulling out on the grill while you mess with the screwdriver to pry apart the tabs.
Takes 4 hands...
Old Jan 16, 2009 | 10:49 AM
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
The FRONT grill? Wheres the rear grill? j/k lol
Old Jan 16, 2009 | 11:15 AM
yoder519's Avatar
i used a flat head screw driver to get the top ones off, then just jsut pulled oit off. and i broke almost all of tehm putting it back on but it holds in just fine. so if you get take it off and then put it back oon w/o breaking any. your the man
Old Nov 5, 2014 | 09:43 AM
YotaMomma78's Avatar
I am trying to remove my grill to replace my right hand side headlight (Lens) on my 93 4Runner and I cant figure out what is holding it together on the bottom. Seems like its right around the bottom where the light is but I cant see anything. All the other clips came off no problem. Any ideas?
Old Nov 8, 2014 | 02:26 AM
Hugh_Mann's Avatar
Did you take your side markers off first? They clip into the sides of the grill and hold it in place. If you're confident you've removed all the clips, all it'll take is some wiggling and prying to pop it loose. Take my advice with a grain of salt though! My grill is held on by 4 cable ties Not a single clip has survived the past 20 odd years.
And just so you know, if you have a question you can always make your own thread instead of bumping one that's 5 years old
Old Nov 8, 2014 | 06:13 AM
I figured it out everyone. I did everything right the first time but I couldn't see the tabs on the bottom of the grill under/behind the headlight. My bumper is bent up into the bottom of the headlight too so that didnt help matters but with a few whacks with a hammer (towel underneath to not damage the bumper) and I got it!!! Thanks for the advice =>
lledwod
Aug 30, 2016 01:03 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
crashburnoveride
Jul 10, 2015 06:39 AM
ItsJustD
Jul 7, 2015 07:49 AM
