Sponsored by: CARiD
striped camry head bolts
Old Dec 18, 2008 | 04:38 PM
Mike Sylvain's Avatar
is this a wide spread problem?
Old Dec 19, 2008 | 06:25 AM
83's Avatar
83
Not sure that you'll find many camry experts here, mostly truck...but I would say no. They aren't overly hard to strip, since the heads are aluminum, but I would say it's a crappy mechanic issue, not a camry issue. So if it's a widespread problem, it's because of a mechanic not knowing what the hell he's doing. You've got to be careful when you work with any bolts on an aluminum head.
Old Dec 19, 2008 | 07:26 AM
trbizwiz's Avatar
helicoil they are around 2 bucks a piece. Requires drilling. Have fun. a machine shop will do it for around $300
Old Dec 19, 2008 | 08:33 AM
DeathCougar's Avatar
Assuming this isn't spam.....
which part is stripped, the head of the bolt, or the threads in the block?
Old Dec 19, 2008 | 09:19 AM
stagger_lee's Avatar
If its the head, just tap it out to the next size bolt. I also put a flexible joint between the downpipe and the rest of the exhaust to eat up the excess vibrations and shock to those bolts and the aluminum head, from the weight of the entire exhaust system.
Old Dec 19, 2008 | 09:40 AM
okie81's Avatar
x2......used to have a camry in college and the helicoil worked like a charm
Old Dec 19, 2008 | 10:49 AM
saitotiktmdog's Avatar
striped as in like a zebra or like a tiger. Or is it more of a kudu striping. Just kidding. Might want to change the spelling in the title though.
Old May 25, 2009 | 04:54 PM
ptowing's Avatar
yes this appears to be a very common problem on 2.4l,the rear head bolts strip out,the bolts are loose on removale,it is not the result of the mechanic not doing his job.check other forums,and check with toyota
kgcwb44
Jan 29, 2023 10:02 AM
dumpster84
Apr 30, 2016 06:03 AM
theking11863
Mar 19, 2016 09:36 PM
Sep 4, 2015 09:27 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
