Sponsored by: CARiD
High idle problem
Old Jan 9, 2009 | 07:43 AM
a1toy's Avatar
High idle problem
I have a 1987 4-Runner with a motor from a 1986 pickup. I did switch the fuel injection back to the 87 but I have a high idle problem. I am wondering how to reduce the idel speed. It idles fast all the time; after starting, after idling for a while and after being operated. By fast I mean about 1500 to 1800 RPM. I live in North Dakota and it has been very cold and it idles fast when being started outside or in a heated shop. It runs fine other than the high idle.
Thanks
Old Jan 9, 2009 | 08:22 AM
4Crawler's Avatar
Make sure the throttle is fully closed, adjust the throttle stop screw out so that the throttle plate closes then turn the stop screw in 1/4 turn and lock. Make sure the dash pot is adjusted properly:
- http://www.4crawler.com/4x4/CheapTri....shtml#Dashpot
Make sure the TPS is adjusted properly:
- http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Make sure the timing is set to 5 BTDC with the timing jumper installed:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
And turn down the idle air screw atop the throttle body.
Charecter1
Nov 6, 2023 10:08 AM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
Poncho0206
Jul 10, 2015 06:21 PM
Jnkml
Jul 6, 2015 01:20 PM
