86 4runner wont turn over
I have an 86 4 ruuner 4 wheel drive with a 22re enngine 5 speed when i go to start it all i get is a click have had the starter, altinator, and battery replaced can anyone help please
See below for some troubleshooting tips:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
Ground from battery and starter ground is a good start. Make sure connections are clean. Obviously your battery terminals are clean, but I always had a problem right where the ground wire connected to the clamp that hooks to the battery terminal. Pull that clamp off and clean the wires up. Maybe cut a little of the rubber back to clean better. Clean clamp connection with a wire brush.
ashersullivan88yota
Jan 18, 2022 05:37 PM
