Sponsored by: CARiD
Running Lean, Vacuum Leak?
Old Dec 30, 2008 | 04:07 PM
Jrunner01's Avatar
Hey Everyone, First Off I'm New To The 4runner World, And I'm Loving It! I Haven't Had The Truck For A Month Yet And I've Done The Deck Plate Mod, Removed Air Silencer, And Painted My Wheels Black.
My Problem Is: After I Drove The Runner Home From The Dealer They're Were No Probs And It Had Passed Emissions And Ran Great. A Few Days Later The Trac, Vcs, And Engine Light All Turned On, Still Ran Great. Took It To Auto Zone And They Said The Code Came Up Running Lean, Vacuum. I've Checked All The Vacuum Lines In Sight For Cracks Or Being Loose But Everything Looks Ok. Last Weekend I Went Up North And Everything Was Fine Till I Started Up A Steep Hill. Once I Hit 3,000 Rpm And 70 miles per hour, I Lost Most Power And Bogged Out The More Gas I Gave It. After I Shifted Into O.d. And The Rpms Went Back Under 3 Grand Everything Went Back To Normal. Can Anyone Tell Me What Else To Look For Or How To Get It Diagnosed? I've Check Past Threads But Not Had Much Luck
2001 Sr5 4runner, 3.4l
Old Jan 1, 2009 | 06:22 PM
bigarms23's Avatar
make sure you vacum lines are in the correct places cause i threw and engine code for crossing some on accident
Old Jan 1, 2009 | 07:09 PM
rimpainter.com's Avatar
I just moved here from north Phoenix. Anyway, get the actual code from Autozone. It might help a bit in the diagnosis. Is it P0171 (System too lean, bank 1)?
Never hurts to follow the entire intake system from the box back and make sure everything is hooked up and in good condition. When exactly did you do these mods by the way? Double check the ISR mod set up for sure. Any extra air in past "the sniffer" (MAFS) will create a lean condition. After double checking everything, let us know.
Old Jan 2, 2009 | 05:49 AM
Jrunner01's Avatar
i did the mods after the lights came on and got the codes checked. i'll see what i can come up with and report back. thanks for the help guys
Charecter1
Nov 6, 2023 10:08 AM
icentropy
Sep 16, 2020 02:47 PM
Colington
Mar 8, 2020 09:51 AM
nick b
Jul 11, 2015 04:38 AM
Avenged
Jul 9, 2015 07:55 AM
