Sponsored by: CARiD
remove hoses? name this part?
Old Dec 30, 2008 | 01:24 AM
jungle_runner's Avatar
i'm pulling my intake but i can't get to the last bolt closest to the rear ... i want to remove the two hoses to get better access to the bolt ... do you know what they are? thanks
and there is one other part that seems to be just hanging under the throttle, looks like it should be hooked to something ... do you know what this is for? thanks
Old Dec 30, 2008 | 02:09 AM
NicCantDecide's Avatar
In the first pic, those two lines are AC lines. I recommend NOT unbolting those, unless you want to recharge your system afterward.
The second and third pic look like the check valve on the vacuum lines. If its orange, that's what it is. Can't tell too well from the pictures. There should be another vacuum line on the other end of it. The vacuum diagram under your hood should show you what line goes where. On the diagram it'll say "orange" right next to a rectangle with a line coming out of each end, that's the check valve.
I have a 3VZE, but that check valve should still be the same.
Old Dec 30, 2008 | 01:26 PM
Originally Posted by NicCantDecide
In the first pic, those two lines are AC lines. I recommend NOT unbolting those, unless you want to recharge your system afterward ... The vacuum diagram under your hood should show you what line goes where.
THanks! I don't use the A/C (doesn't work anyway) so I'll remove those (they started hissing compressed air)
Interesting, so there should be a tube on the other side of that check valve... it's just taped closed ... I wonder how long it's been like that ... there's no vacuum diagram under my hood
THanks!
Avenged
Jul 9, 2015 07:55 AM
skoti89
Jul 8, 2015 12:05 AM
ItsJustD
Jul 7, 2015 07:49 AM
wilbertd
Jul 6, 2015 07:39 AM
HRDC0R19
Jul 5, 2015 06:43 PM
