tranny swap question
i'm replacing the transmission in my 2nd gen 4runner. the replacement tranny has 150k miles on it. i've got a front seal ready to install. i was wondering if there are any other seals i should replace at this point on the trans or transfer case.
Manual or auto? I am assuming we are talking auto since you said front seal. In that case, you will want to replace the trans pan gasket (which should be a sealant, not a gastet) and obviously the fluid. Other than that, the only seal I can think of are the flange seals which are a PITA to replace.
Although the Toyota manual transmissions are fairly bullet proof, there is no way that I would drop a 150k gearbox of unknown history into my truck without opening it up.
Most likely, I would at least recondtion it, if not do an all out overhaul.
ok there is a front and rear transmission seal.they were both getting hard and cracking so i replaced them.i may check those flange seals soon as well. it was a bad front flange seal that caused my output shaft bearing to fail on my first truck .it didn't leak gear oil, but it let some water get in.
Iceman4193
Jul 15, 2015 04:48 PM
madxman21
Jul 9, 2015 10:26 AM
