Sponsored by: CARiD
Setting Timing-why plug the vacuum lines?
Old Dec 16, 2008 | 08:11 AM
83's Avatar
83
I've seen to set the timing at 0 with the vacuum advanced plugged (actually at my elevation it'll be a little different, but still), but then I've seen people saying to set it at 12 degrees if you don't plug the lines, so...what's the benefit of plugging the lines? If you can just set it at 12 and not bother plugging the lines, why do it? I'm assuming that there is a reason, but if not, I'm not going to bother plugging them.
Old Dec 16, 2008 | 08:48 AM
4Crawler's Avatar
I imagine because with the lines plugged you have a known condition for setting the timing, the distributor will not be artificially advanced or retarded by the external vacuum lines. The problem with engine vacuum is that it is not a constant value from engine to engine nor at different elevations or weather conditions. You could always do a check on yours, set the timing plugged, then reconnect the lines and see how the timing has changed.
Old Dec 16, 2008 | 10:33 AM
83's Avatar
83
Thanks, I'll go ahead and plug them when I do it. I figured there was a good reason, but wanted to make sure.
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
TokyoD23
Jul 12, 2015 06:01 AM
skoti89
Jul 8, 2015 12:05 AM
bryan34w
Jul 6, 2015 05:53 PM
