Sponsored by: CARiD
driveshaft/ t-case shifter ???
Old Jan 11, 2009 | 04:39 PM
DWEINBERG01's Avatar
When I am in 4lo and under load (climbing anything) my driveshaft flange grinds on the horseshoe that connects to the t-case linkage. When it does this, it causes the t-case to jump out of 4lo into 4hi and sometimes as far as 2hi.
Is my driveshaft out of balance or is there a bigger problem?
Tranny and t-case is the A340F.
Old Jan 11, 2009 | 04:42 PM
tc's Avatar
tc
Molly's does the same thing, but I never heard/saw any grinding - sure it's hitting the collar?
There is a bushing on the bottom of the horseshoe that might be worn out ... it was on Molly's, but fixing it didn't keep it from popping out of gear.
Old Jan 11, 2009 | 04:57 PM
Yeah, it's hitting the collar, I found metal shavings on the collar. I already replaced the metal "shims" inside the barrell at the bottom of the collar. I'll check the buching when I get home.
Molly, if you want to chime in and let me know how you ended up fixing your's I would love to hear it. I am open to anything.
Old Jan 11, 2009 | 06:09 PM
tc's Avatar
tc
She fixed it by blowing the motor - hasn't popped out of gear in about a year ... but then it hasn't moved either! LOL
Old Jan 11, 2009 | 08:15 PM
OH. Bummer. Okay, I guess trial and error will have to do then. Molly- Hope you get your rig runnin.
mwisham
May 26, 2021 02:51 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
irv
Sep 22, 2015 11:51 AM
briholt
Sep 20, 2015 10:26 PM
