Sponsored by: CARiD
Master Cylinder problem?
Old Jan 2, 2009 | 02:50 PM
dub84's Avatar
i drive a 1984 toyota pickup. its a dlx so its extended cab and such. my problem is my brakes. i just did a 4 wheel brake job and i still have a low pedal and only my front brakes work. It also leaks brake fluid, i have to fill it every couple of hours. its getting annoying so im wondering if its my master cylinder thats broke?
Old Jan 3, 2009 | 03:48 AM
abecedarian's Avatar
can you tell where the fluid is leaking?
after doing the brakes, did you bleed all 4 wheels then the LSPV (the load sensing proportioning valve above the rear axle)?
Old Jan 3, 2009 | 04:25 AM
dbcx's Avatar
X2 where? That is a pretty big leak. Is it leaking constantly or just under pressure?
Old Jan 3, 2009 | 05:04 AM
waskillywabbit's Avatar
Did the brakes work before?
(4) wheel brake job consisting of doing what?
Leaks brake fluid where? Out the tailpipe?
What was your bleeding procedure?
Old Jan 4, 2009 | 12:13 PM
dub84's Avatar
bled all four brakes, did not bleed load proportioning valve, and i believe its leaking out of the back passenger side wheel cylinder because it was bad, but it leaks under load or not...if i fill it and park it, it will be empty by morning...i should have it fixed soon because i went to NAPA yesterday and ordered wheel cylinder and master cylinder, if that dont work then im jumping that P.O.S
Sleaker
Aug 26, 2020 06:03 AM
jasonty
41
Dec 23, 2018 01:00 PM
mskalmus
May 28, 2017 07:51 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
kyletbert
Jul 17, 2015 11:39 AM
