Sponsored by: CARiD
New headlights
Old Jan 10, 2009 | 02:31 PM
Clark20's Avatar
New headlights
Do I need to take the grille off to do this? I tried getting the grille off and it is a b!tch, and I am getting frustrated. How the hell do I get this thing off?
Old Jan 10, 2009 | 02:39 PM
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
What kind of truck is it?
Old Jan 10, 2009 | 02:57 PM
Belize Off Road Team's Avatar
No, just get a really long screwdriver and make sure not to scratch the headlight surround to much, ( 85-95 4Runner/Pick-up)
Old Jan 10, 2009 | 02:58 PM
Clark20's Avatar
Sorry, it's a '93 ext. cab dlx 4x4 'yota with the 3.0.
Old Jan 10, 2009 | 03:00 PM
Clark20's Avatar
I think the front end was tweeked because the grill covers up a couple of the screw heads. Thats why I think I might have to remove the grill. Thanks for your help, I could be wrong though.
Old Jan 10, 2009 | 03:05 PM
toylocost's Avatar
Pretty sure there are a bunch of little plastic clips that you have to squeeze and will probably break.
Old Jan 10, 2009 | 03:07 PM
aviator's Avatar
It's a PITA but there is usually enough flex to getat the two phillips head screws on the top as for the bottom two you may find it easier to just loosen them off.
Unplug the light from the back before you start and then just push the light forwards. Drop the new one into the ring and fold it back in. tighten the bottom screws after you put back the two top ones. reconnect the plug and you're done.
don't forget to check the aim as well.
Old Jan 10, 2009 | 03:17 PM
Clark20's Avatar
I'll give it a shot, thanks!
Old Jan 10, 2009 | 03:22 PM
86tuning's Avatar
put in a hella h4 conversion, then you can change just the inner h4 bulb next time.
Old Jan 10, 2009 | 04:47 PM
Clark20's Avatar
I will in the future, funds are pretty tight right now and the cheap $12 replacements will have to do for right now.
Old Jan 10, 2009 | 06:07 PM
Elton's Avatar
i took the grill off well most of the clips where broke so 4 zip ties held it on was pretty easy to take it off
Old Jan 10, 2009 | 09:09 PM
Clark20's Avatar
Got the new headlights in, quite the difference even going with the cheapest lamps I could pickup locally. I don't think the headlights had ever been replaced before and with 170+K on the truck it was definately time. I didn't have to take the grill off just use 2 screw drivers and pry the grill a little while I took the screws in and out. Thanks for everyone's help.
kawazx636
Oct 6, 2021 03:03 PM
4banginRunner
Nov 13, 2015 05:23 AM
mreagen
Oct 5, 2015 04:27 PM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
