Sponsored by: CARiD
Proper rear main replacement
Old Nov 30, 2008 | 08:13 PM
91diesel's Avatar
I just did some work to my toyota and among the things I did was replace the rear main seal (On a 3.0L turbo diesel....) anyway it uses the same kind of retainer system as other toyota engines and my question is this. What is the correct placement of the seal in relation to the edge of the retainer? Mine actually pushed in past the edge toward the block, and on top of that it looked like the retainer's edge was beveled toward the engine block, so what is supposed to keep the seal out flush with the edge of the retainer? I ask because now instead of some occasional drips, I'm getting a really cool flow out of the rear main, and by really cool, I mean I want to #%^$#@^@$^!%^!)!#$%*$#%)*$_#*)^%!)#$^_#%*()$_^*()! !!!!! Thanks for any input.
Also, any thoughts on when I go back in there, just putting another seal on top of that one so that it sits flush with the edge of the retainer? Plus I'll have two rear main seals!! There looks like there is enough room to do this.....
Old Nov 30, 2008 | 08:20 PM
TOYOTA 1's Avatar
i usually just tap them in until there flush, but Ive also put them in all the way until they stop. both ways with no problems..
the way your describing it, sounds like you damaged the seal during installation..
how did you "finesse" it in there?
Old Dec 1, 2008 | 04:09 AM
91diesel's Avatar
The seal wasn't damaged, I slid it carefully over the crank and then tapped it all around while holding the side 180* out from where I was tapping. It kept bouncing out at first but I just kept at it and it tapped in (nice and gentle) but when it did, the side 180* out from where I was tapping recessed so I evened the whole thing out (recessed). I obviously did something wrong, I think the seal has to be flush with the retainer edge to work properly, I just don't know why it would be set up to easily recess like that, maybe make removal easier?
Old Dec 1, 2008 | 10:52 AM
TOYOTA 1's Avatar
i always just tap them in flush also, some people think thats wrong and tap them in untill they stop.. but like i said ive never had a problem and ive used both methods.. did you inspect your crank?(where the seal rides)..
sometimes the seal itself will ware a groove in the crank.. that could be it?
if thats the case, search speedy sleeve. i think thats what its called.
Old Dec 1, 2008 | 12:05 PM
91diesel's Avatar
Some of the diesel guys have said the problem is tapping it in too far. It needs to be just flush with the retainer. The motor only has 60K on it so the crank looked fine. Damn it's gonna be a pita redoing that!
Old Dec 1, 2008 | 12:38 PM
jason191918's Avatar
I put mine in flush and got the said speedy (or kwik/quick or something like that) sleeve from rock auto.
warrenjcarlson
Jul 22, 2016 11:47 AM
jennygirl
Nov 17, 2015 11:24 AM
Alaskan91
Sep 21, 2015 04:39 AM
Jmiller1023
23
Aug 6, 2015 07:03 PM
cchinny
Jun 25, 2015 08:11 PM
