View Full Version : Newbie Tech Section
- Need help fix rear axle gear seal leak
- obd code po133
- uneven front end
- Reliable mech needed in ATL area
- What should happen when I pull the EFI fuse?
- Jack Suggestions
- SA inner axle question
- School me on the term "pig"
- 1990 22re temp gauge question
- 1988 Hiace 4x4 truck 2.4 diesel
- bumpers and more
- help my 4runner wont start
- Write up for replacing 01 4runner alternator?
- Will 15x7 wheels of '95 4R fit an '03 Tacoma?
- Bumper or locker
- Cheap Steels and any tires.
- Anybody know of a online FSM for 79-83 pickups
- n00b question re: sliders
- Questions about Stock options for 2nd and 3rd Gen 4Runners
- Clean engine
- CV Replacement Question
- Iirc??
- spark plugs
- Definitive answers to air intake situation?
- I was told I could not allign my 4runner if I added 2" spacers.
- Hammerite issues?
- Used 4Runner Issue
- Something went horrably wrong....
- Timing issues
- idle air control actuator
- ball joint spacer
- Advice Requested; Plastic Floor Liner Removal.
- 4Runner newbie, first post, a few basic questions...
- Is there a way to tell which radiator is in my truck without actually measuring it?
- Sheet metal + Tubing
- Replacing rotors
- strut question (I'm confused)
- Newbie and I wanna rebuild my 22re
- Synthetic gear oil
- Rollbars (light bars) and such...
- Air conditioning smells like an old sock
- Stupid Theives-Broken Window
- oven cleaner
- I got a question about ome lift with 4banger 3rd gen?
- Got my first Yota.
- Need Advice 3" OME lifr or Skid Plates
- Need some help
- backspacing ?
- front diff. drain plug!!!!!
- Requesting your help in Kenosha WI !!
- 1996 4Runner glove compartment
- power steering question about crankshaft
- Help!! Fuse melting
- Self muffler installation question
- clutch question
- ball joint spacer question
- Tool Rack question
- Daytime running lights on 01 4runner
- rear diff help
- How does the 04 4Runner spoiler has been attached?
- a/c compressor not kicking in
- Muffler Question
- i have some connectors left over from my engine install. im almost done ... help
- Adjusting the idle on an 86 4runner
- Is this Toyota factory coolant?
- How to adjust Parking Brake on 2004 4Runner???
- 1990 swap to 3.4L - is body lift needed?
- Ajusting E-BRAKE??
- space lift
- bad clutch bearing?
- '91 Hilux Surf Overheating(surpirse surprise)
- Tailgate Widnow Arms
- CEL on Camry
- Back firing and sputtering when i first start?
- What is this 3.0 TB Screw?
- Hi-Lift Questions? Which one?
- 1st Gen. Ball Joint Lube
- bed weight and ride quality
- what to do witht he 4runner
- carb ?
- 85 Truck Decision Time
- I've searched!! Does anyone else have alignment issues after multiple realignments??
- MAF Part Number differences?
- Who has removed the TRD Off-Road decal?
- temp
- Havin Hard TImes 88 4runner
- Build up question
- help gear ratio question
- What oil to use?
- adjust rear breaks 87 4Runner
- ISR pipting help.
- BRAKES! Master Cylinder?
- could some one explain how regearing works
- 2wd break down...
- ideas for bike racks - good or bad
- Help spending money on 95 yota..
- 3 groove crank pulley? for 85 pick-up 4x4
- Looking to replace engine. Suggestions/Recommendations?
- how do i check control arm bushings
- good buy?
- Snorkel Fit?
- a/f ratio
- Exhaust
- YT rig thread
- Noob drum brake questions-
- Strange noises from 2007 Tacoma
- OME Torsion Bars Question
- Towed my boat at 250 miles, what now?
- Small front end lift?
- Help :)
- Exposed wire connections
- Favorite Part Sights For Pick Ups
- Total noob!
- 22r carb issues-Weber upgrade?
- 2wd only works in 2h
- Coilpack Replacement Interval
- Need help picking a truck.
- Re. a personal thread
- skid plate
- replace tensioner w/out doing full tbelt job?
- Serious newb question on shocks
- 2002 4Runner modifications
- Best way to locate a replacement engine
- Noob wheel bearing help PLEASE!!
- ATS Location
- 22RE - Will an 87 Cold start injector work on a 94 model?
- Daughters first vehicle starter questions
- Clarification: preload vs. topload spacers and AAL strength
- another first timer
- Bad MPG
- Valve Cover Gasket replacement cost
- 4runner rotors q's
- Fire order an placement of wires to cap.
- converting inch lbs. to ftoot lbs
- How Much would one of these be worth now!! Slightly O/T
- i already searched! 255/85R16
- Need help getting truck to start
- Heavy gear oil in rear diff ok?
- Toyota Running Rich/Running Lean? NEED HELP!
- Define "Rebuild"
- A/C Question for the CO Metro Area
- JDM engine question
- Will a 2000 grille guard fit a 91
- 99 4runner engine ping
- Newb 4Runner questions
- crank pulley????
- Sticking Throttle After Weber Carb Install
- What else do I need
- Panhard bar really needed???
- First gen '87 questions
- Looking for bigger than 3" lift for 4th gen.
- diff drop
- Forerunner doesnt like puddles
- Help on suspension
- Toyota 4runner
- Time to start in on my first yota.
- Adding Keyless Entry 1990 4-Runner
- fj cruiser gauge cluster in 02 taco
- driveshaft ?
- Looking for low cost performance mods / 22re
- Do coil springs get worn out or just "broken in"
- 3.0 Coolant Leak Under Intake Manifold
- Hi idle
- Timing cover seep question
- 99 tacoma 2" lift
- Throbbing idle, need help
- Stock starter relay to painless Hotshot
- Spun Rod, Main Bearing
- 91 4runner code help
- 86 2wd to 80 4wd engine/trans swap?
- 22R Engine
- fule filter location
- Weeee! Got another Yota, now need some tech advise
- Backspacing question
- Maintenance on '00 4runner
- tire size recomendation
- shock length
- Looking for a tow vehicle, will a yota fit the bill?
- What's the small cavity in the center console in later 3rd gens for?
- revtek
- cruiser springs in 4runner
- 85 4runner engine?
- Symptom of A/C going out?
- What happen if i put 4.88 gears with 30x9.50 tires
- Plugs for 2004 v8 4Runner????
- annoying ticking
- Steering Wheel Vibration 2001 4-Runner
- Master Differential Install Kits
- Help: How to get a Microfish(parts illustration)?
- Oil Filter access on 04, v8, 4Runner?????
- 93 4runner 22re engine knock...
- Will this Oil Filter work on my 2002 4Runner?
- Is 2,600 RPM at 70 MPH Normal??
- Got a package in the mail!! Question
- Asap!
- taking off panhard rod for coil install
- When to use clutch start button
- Sequoia Vs. Land Cruiser Rims
- 4.3 swap pros & cons
- Stock Springs 1997 4runner
- Stored 87 4runner won't start
- Lift gearing and tires question
- Freeze plug in back?
- how wide can i go
- Will springs and shocks from a 2003 4Runner fit a 1997 4Runner??
- need pics from seat swap in reg cab
- Brakes....
- rough idle when cold
- How do you lubricate the front window channels?
- 22re engine problems
- E-Brake Cable Size
- power lock problem
- buying a new runner, what should i look out for?
- Sap on truck?
- Brake Light Question
- backspacing question
- Fender flare questions
- Cold Air intake vs Deck plate mod
- ARB bullbar fit question
- EGR Problems? Or not?
- "Master Differential Install Kit" OEM vs Aftermarket?
- Wire Gauge and Aux Fuse Box
- Tranmission problem? irvine / oc
- engine swap
- 3.0 V6 headgasket solutions
- Crossover-Hi steer question
- 1987 hilux
- door locks
- blew up my 22re engine- What will kind of engines will fit in my 4 runner
- Short in the EFI
- spark plug location?
- Help this stupid guy out on my 00runner
- Permatex #80697 Copper Gasket Seal
- DOT Regs on offroad tires
- Paint repair after removing running boards
- Cold Water Driping on my feet???
- How does a beadlock work?
- What size tires can I go w/o a lift??
- Landcruiser vibrate while braking
- bigger tires and lift question from Newb
- Another thread about filters
- LSPV '93 pickup
- Axle Interchange
- Problems Engaging Any Gear...
- Can't Remove my 94 4x4 Front Brake Rotors
- Oxygen sensor... Which one?
- Goin to look at '98 Runner...thoughts?
- Difference between 4 Runner and Landcruiser?
- Who has lift laws?
- Where is idle speed adjustment screw located?
