Sponsored by: CARiD
help gear ratio question
Old Jun 9, 2007 | 05:56 PM
CASTAIC 4RUNNER's Avatar
i have a 1999 toyota 4runner sr5 4wd 3.4 liter v6 5 speed manual... i was going to regear for 32 inch tires but i hear people dont notice a difference, and i hear they do notice a difference i dont know what ratio to go with i dont even know what ratio i have stock. if you know what my ratio is PLEASE TELL ME!!! i cant find it on the internet or anywhere...
Old Jun 9, 2007 | 06:03 PM
hud's Avatar
hud
from one YT noob to another:
Do you have the factory locker?
What's your axle code?
You could jack up one rear tire (open diff) and turn the driveshaft once. Count the revolutions the tire makes and multiply times two.
that said, there's a good chance you have 4.30s.
Old Jun 9, 2007 | 06:12 PM
i dont have the diff lock...what are the biggest tires you would go with those gears
hud's Avatar
hud
Boolean search reveals all ... my young Paduwon.
http://toyota.off-road.com/toyota/ar....jsp?id=274535
http://www.4crawler.com/4x4/4R_TechInfo.shtml
Old Jun 9, 2007 | 06:17 PM
hud's Avatar
hud
w/o the locker, you might have 4.10s
With your engine, and either 4.10s or 4.30s, you should be able to run up to a 32 without too much difficulty. People run everything. 33s is probably pushing it, but if you stick with a narrow tire (like the bfgs in 33x10.5), it wouldn't dog as much.
I had a 91 with 4.10s and a 4cyl, and I ran 31s on it comfortably. My 98 runner also has the 4cyl, and I'm running 32s with power to spare, imho, but it has the 4.56s in it.
What tires do you have now?
The popular choices are a 265/75/16 or a 285/75/16, which are 31/32 and 33 respectively.
Old Jun 9, 2007 | 06:28 PM
MudHippy's Avatar
This is worth a look.
http://www.vibratesoftware.com/html_...ear_Ratios.htm
4.88 for 33s, is optimal.
Old Jun 9, 2007 | 10:45 PM
i have 265.75.16 bfgoodrich all terrain's.. 31.6 size
Old Jun 9, 2007 | 10:49 PM
Elton's Avatar
pretty sure mine has 4:10s
Old Jun 9, 2007 | 10:56 PM
how would you know did you go online
Old Jun 9, 2007 | 11:07 PM
MudHippy's Avatar
Unless you have the 3.90s, you probably don't "need" to regear for 31.6" tires. I have 4.30s and 35x12.5s and my V6 turns 'em just fine.
You do realize you'll lose top end speed (max mph) if you go with lower gears?
Old Jun 9, 2007 | 11:10 PM
ok what gears would be perfect for 33s
...ya i knew that
Old Jun 9, 2007 | 11:24 PM
MudHippy's Avatar
Just tryin' to help "friend". But, if you suddenly know everything there is to know about gearing for Toyotas (a little obvious as to the answer to that), then I'll be on to the next thread. And, your welcome, by the way (assuming you checked the link I gave you, if not then maybe you should try another forum for better advice).
Old Jun 10, 2007 | 08:28 AM
tc's Avatar
tc
For our older motors, yes, but for the 5VZFE, I would do 4.30 or maybe 4.56 for 33's as they don't like to (and certainly don't NEED to) be revved like our motors do.
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
mskalmus
May 28, 2017 07:51 AM
coffey50
Jul 28, 2015 10:55 AM
smiley52
Jul 11, 2015 05:16 AM
