Sponsored by: CARiD
22r carb issues-Weber upgrade?
Old May 30, 2007 | 02:08 PM
G-off's Avatar
So I got an 87 with a rebuilt 22r and stock carb. The truck has been sitting for about 3 years and has 214k miles. So I drained all the gas, put new fuel line in, replaced the fuel pump and plugs, new oil, but it won't run for crap. Won't idle or rev, just sputters.
So anyways, I took the carb off thinking to clean it out but I can't get the air horn off because the screws are seized up so I was thinking about just tossing it and trying a Weber now. It definitely looks like it has seen better days.
The truck is going to be a desert prerunner, not a daily driver or crawler. I also plan on running an engine cage so I would like to minimize clutter, and I also have a 32 gallon cell, so fuel economy isnt much of an issue. Engine is stock but I do plan on putting headers on it, maybe a cam in the future.
So would the Weber 38 be a good choice? Or any other ideas on getting it running again?
Thanks...
Old May 30, 2007 | 04:19 PM
tc's Avatar
tc
I had a 32/36 on my '89 - was great. Plenty driveable, with real good power when the secondary opened.
Recommend a header too ... mine was a Pacesetter - it sucked, was always fighting exhaust leaks at the flange. Get a Thorley or a NWOR...
Old May 30, 2007 | 04:25 PM
pennywize's Avatar
i have a weber 32\36 and a thorley header on my '79. runs great, super smooth and starts right up. i got the electric choke version and plugged all the coolant ports on the manifold, i don't know if the 87's had water or electric chokes from the factory though.
i would say get a weber!
Old May 30, 2007 | 04:28 PM
tc's Avatar
tc
My '89 was electric choke
Old May 30, 2007 | 04:35 PM
toy power's Avatar
i have a 38 on my 22r, has a pretty big cam and header. that thing makes so much more power than the stocker. i actually ran the motor after i built it with the stock carb while i was waiting for the weber in the mail. unbelievable difference. you won't be disappointed.
Old May 30, 2007 | 06:14 PM
G-off's Avatar
Cool thanks guys.
Guess I'll go with the 38. Is this a good deal? http://cgi.ebay.com/ebaymotors/Toyot...spagenameZWDVW
Can't seem to find them anywhere else.
Old May 30, 2007 | 07:16 PM
tc's Avatar
tc
Seems like a lot of money to me, but I hear Weber prices are A LOT more expensive now than "back in the day". LC Engineering has it for the same price, and they're a known supporter of the Toyota community...
http://www.lcengineering.com/newslet...p?p=view&id=19
Want pimp? Go sidedraft!
Old May 31, 2007 | 02:11 PM
G-off's Avatar
LC is like $460 for their Weber conversions now. And $1500 for the sidedrafts...ouch.
Other question, electric, manual, or water (?) choke?
Old May 31, 2007 | 02:15 PM
tc's Avatar
tc
Ohhh - didn't check the date on that newlsetter I linked to ... oops
Old May 31, 2007 | 02:17 PM
toy power's Avatar
yeah that is a good price. i paid 390 for mine.
Old May 31, 2007 | 10:40 PM
herpestes's Avatar
www.racetep.com
Old Jun 7, 2007 | 09:21 PM
G-off's Avatar
So I got my 38 today. Does anybody know how to hook up the electric choke on it? Wiring is not my strong point...
Old Jun 8, 2007 | 04:52 AM
tc's Avatar
tc
One wire to the side - there's a little screw over a white plastic cylinder.
Old Jun 8, 2007 | 07:35 AM
G-off's Avatar
You mean on the carb or on the truck? I see where the one wire plugs to on the carb, just don't know where to take it to. Instructions are pretty weak too...
Old Jun 8, 2007 | 04:51 PM
G-off's Avatar
Got the carb on and it runs great now, however its spewing oil all over the back passenger side. I would assume its coming out of the hole in the block where the EGR used to be? The kit comes with a block off plate for the intake port, but not the back one...Do I just need to block it off or did I have a vacuum line wrong?
Old Jun 8, 2007 | 05:35 PM
tc's Avatar
tc
Picture?
Old Jun 8, 2007 | 07:23 PM
G-off's Avatar
No pics, trucks not at my house and I forgot to take my camera. I'll see if I can get it sorted out tomorrow, if not Ill snap some pics. Im hoping its that EGR port on the block or something else simple, and not the block/headgasket...
Old Jun 8, 2007 | 07:25 PM
tc's Avatar
tc
I'm pretty sure it needs to be blocked off, but not 100%...
Old Jun 10, 2007 | 01:07 AM
herpestes's Avatar
you can either get the egr block off plate for the head from LCE or use the gasket and fashion your own
Old Jun 10, 2007 | 06:56 AM
G-off's Avatar
Yup, ended up making my own out of some .125" plate. No oil leaks now. Next problem is fuel delivery. Bought one of those spectre fuel regulators form Checkers but all it does is severly restrict the flow. Anybody run an electric fuel pump on these? And would it be OK to drive it about 20 miles with no regulator (direct from the stock mechanical pump)?
