Sponsored by: CARiD
ball joint spacer
Old Jul 14, 2007 | 10:05 AM
TheGhost's Avatar
ball joint spacer
pros and cons of ball joint spacers? i tried to search it but couldnt find a real answer.
Old Jul 14, 2007 | 01:05 PM
ovrrdrive's Avatar
Pros: cheap, 1.5" true lift, easy to install.
Cons: None. They do what they're supposed to.
It could be said that if you use them for lift and not flex that they will put a higher angle on your CV's, but they're still better than a tbar crank and there are thousands of trucks that have done that and been fine. Myself included.
Old Jul 15, 2007 | 01:20 AM
vwfastg60's Avatar
Pro- Down travel seems like way more then 1.5 inches, You can relax the T-bars and accually flex the front and ride soft. drop the diff and your even better for downtravel.
Con- I hear that they wear out balljoints faster but havent seen it at all. Softer suspension makes things feel smaller so you tend to push harder. Your butt will be sore from kicking your self after thinking you should have done it earlier.
the only real con is if you dont drop the diff then your CV boots look like mine. I plan on doing that when i get new shafts.
pic of 4inch lift and Bjspacers. I relaxed the bars and am accually lower then i was but have so much more usable suspension its worth a bit of rubbing and cutting.
Stock Straight
Old Jul 15, 2007 | 07:16 AM
Kyle95sr5's Avatar
So you typed "ball joint spacer" in the search thing and came up with nothing? I must have the super duper high powered search button on my YotaTech page!!
https://www.yotatech.com/forums/f116...pacers-103761/
https://www.yotatech.com/forums/f2/o...spacers-33528/
https://www.yotatech.com/forums/f31/...riences-90269/
https://www.yotatech.com/forums/f116...rs-safe-90949/
https://www.yotatech.com/forums/f31/...spacers-66158/
https://www.yotatech.com/forums/f116...rmation-97672/
https://www.yotatech.com/forums/f31/...ift-ifs-69318/
https://www.yotatech.com/forums/f116...n-bars-102416/
https://www.yotatech.com/forums/f116...ptions-109906/
https://www.yotatech.com/forums/f31/...pacers-107579/
https://www.yotatech.com/forums/f31/bj-spacers-69916/
https://www.yotatech.com/forums/f31/...blowout-65227/
https://www.yotatech.com/forums/f31/...uestion-58081/
https://www.yotatech.com/forums/f31/...-beware-57894/
https://www.yotatech.com/forums/f31/...on-bars-55455/
https://www.yotatech.com/forums/f2/b...uestion-52737/
https://www.yotatech.com/forums/f2/b...-faulty-40640/
https://www.yotatech.com/forums/f2/b...-issues-36555/
https://www.yotatech.com/forums/f2/m...ranking-22870/
You've got to be kidding me
Old Jul 15, 2007 | 08:03 AM
WATRD's Avatar
Thread moved to the noob section where it belongs. There's tons of info on this...
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
crash813
Sep 27, 2015 07:15 AM
