Sponsored by: CARiD
front diff. drain plug!!!!!
Old Jul 3, 2007 | 04:09 PM
exoyota's Avatar
ok well iam new here guys! so here goes!
ok well i have a allen head drain plug that is smooth all around the outside from Trail-Gear! i have had a problem with them coming loose from rocks on the trail! i actually ripped one out this past weekend! has anyone shaved theres off? if so did u relocate it or just do away with it? the truck is not used all the time it is trailered where it goes so i as gonna shaved it off and do away with it! i dont go threw mudd or water! what do u guys think??? just a little insight would help! thanks guys!
Old Jul 3, 2007 | 08:27 PM
deserttoy84's Avatar
just make some armor for your diff so rocks cant get to the bolt. Ive heard of drain bolts coming loose, definantly not anything new.
Old Jul 3, 2007 | 08:33 PM
Kaleb's Avatar
Just weld a small tack, when you need to change the oil you can then break it.
Old Jul 4, 2007 | 08:41 AM
exoyota's Avatar
i like the tackin idea never thought of that! thanxs guys!
Old Jul 4, 2007 | 08:55 AM
drew303's Avatar
how does the round one come loose?
Old Jul 4, 2007 | 10:51 AM
BeaterToyota's Avatar
Grinding over rocks. Once the first rock grabs hold and spins it some, they come out really easy.
The solution is to weld the drain plugs in place. Then replace the bottom two third member studs with bolts. To drain the oil, just remove these two bolts.
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
Gamble_STi
Jul 7, 2015 07:54 PM
bryan34w
Jul 6, 2015 05:53 PM
elwood73
Jul 5, 2015 07:07 AM
