Sponsored by: CARiD
What else do I need
Old May 15, 2007 | 11:18 AM
mikehinthehouse's Avatar
What else do I need
Ok just a quick summary, I bought my truck used with 88k 3.4l a few months back... have changed oil and got true flow, well Im about to do major service work. this is what Im gonna get... my ? is what else am I missing... Im about to take a long road trip and want it tip top!
1. timing belt
2. water-pump
3. tsat
4. 2 cam seals
5. 1 crank seal
6. 3 drive belts
7. denso plugs
8. sea-foam
9. intake cleaner
10. toyota antifreeze
all parts will be toyota oem...
is that everything?
thanks guys
mikeh
Last edited by mikehinthehouse; May 15, 2007 at 11:25 AM. Reason: forgot that part
Old May 15, 2007 | 11:20 AM
Elton's Avatar
6-pack ?
Old May 15, 2007 | 11:24 AM
yea let me edit
Old May 15, 2007 | 01:56 PM
MudHippy's Avatar
Brakes are another crucial area that I'd take a look at for a long haul. You got the engine covered there, I think. I want to say lube the chassis, but I don't know what that entails on your rig. Also, make sure all the things that need gear oil, are full (axles/tranmission/transfer case).
Old May 15, 2007 | 02:22 PM
tc's Avatar
tc
I would change ALL the fluids - gear oil (tranny/diffs), coolant, brake fluid (just bleed them really well), power steering (note; it takes ATF not power steering fluid), etc. Hopefully, the PO stayed on top of it, but at least you'll know where you're starting from and that there is good quality stuff in there.
Also, all the stuff you normally check before a big trip - windshield wipers, lights, tires, etc
Old May 16, 2007 | 08:36 PM
Spanky's Avatar
wow... i think this is the very first time that i have agreed with tc
Old May 16, 2007 | 08:37 PM
tc's Avatar
tc
Yeah, you're finally coming around to see the light!
Old May 16, 2007 | 10:33 PM
Spanky's Avatar
ha ha and he even respsonds.. thats awesome
Old May 17, 2007 | 10:28 AM
I just did the tundra brakes upgrade and changed tranny fluids... diff fluid was done a few months ago... I think that is about everything...
Old May 17, 2007 | 10:17 PM
Spanky's Avatar
....uhh ok
