Sponsored by: CARiD
a/c compressor not kicking in
Old Jun 26, 2007 | 05:28 PM
toyotaordie's Avatar
need a little help with the ac compressor last year everything worked flawlessly this year i hit the old ac button and it doesn't kick the compressor in? is there a fuse in the box for the ac?? if so which one? its getting a little muggy here in good old indiana.....
thanks
Old Jun 26, 2007 | 05:34 PM
eric-the-red's Avatar
The fuses are on the passenger side kick panel, behind the glove box. Also if the refrigerant pressure is low the compressor won't run.
Old Jun 26, 2007 | 05:35 PM
excableguy's Avatar
someone correct me if I'm wrong, but if freon gets too low in the system, i think a low pressure sensor kicks in and keeps any further damage occurring to the A/C system--maybe you are low on freon?
Old Jun 26, 2007 | 05:57 PM
thanks for the info i know that there are some fuses on the drivers side by my leg i assume that is the only fuse box but we all know what happens when we assume. this is an 86 if that makes a difference as for the freon being low ill have to check that out. can this be done by checking the charge on it i have no idea?
thanks
Old Jun 26, 2007 | 06:39 PM
excableguy's Avatar
yea--if you can afford a professional, he/she can put gauges on it and correctly check pressures,then vacuum it down, check for leaks, and recharge it with the proper amount of oil and coolant. Me, I just bought one of those 35.00 recharge/retro kits and used it's dummy gauge to refill my '91... It worked like a charm for me, but I'm not sayin it was the right way, either!
Old Jun 26, 2007 | 08:58 PM
colsoncj's Avatar
You are correct, there should be a low pressure cut-out switch. It is usually near the dryer, but not always. If there isnt enough pressure in the system, it will prevent the compressor from kicking on. Additionally, if the switch is bad, it will prevent the compressor from kicking on as well, even if you have enough refridgerant.
Badlander
Oct 10, 2015 08:05 PM
Ktm526
Oct 7, 2015 05:14 AM
bryan34w
12
Sep 30, 2015 02:50 PM
rmill05
Sep 27, 2015 01:43 PM
runnermedic
13
Sep 21, 2015 05:20 PM
