Sponsored by: CARiD
Fire order an placement of wires to cap.
Old May 20, 2007 | 07:46 AM
YotaTwist's Avatar
Ok guys I have got some hint on how to fix this just dont know if I have the wires right on the cap. If anyone can help with this it would help me alot. Oh yeah its a V6
Old May 20, 2007 | 08:57 AM
DeathCougar's Avatar
Which engine? 22R runs 1-3-4-2
make sure the engine is at TDC on the compression stroke.
Old Jul 17, 2013 | 03:28 PM
TOYOTA PROSPECTOR's Avatar
Hello dude. I had 82 22r eng rebuilt and i wanted to know how to make sure eng is at top dead center after it was rebuilt. I have valve cover on already. Can i take a screw driver and see if piston is up in cylinder? Or do you know? Please help. Thanks, george 770-880-1106 toyota prospector. Ga
Old Jul 17, 2013 | 03:49 PM
rokblok's Avatar
Hello dude. Pull the valve cover off to verify both valves are closed. Then you can also see the timing marks on the cam pulley along with the crank pulley down low.
A screwdriver in the spark plug hole will tell you if the piston is at TDC, but doesn't indicate whether its on compression stroke or exhaust stroke. Just my thoughts on how I would do it.
Old Jul 18, 2013 | 02:34 PM
Punchy's Avatar
Its odd that the cap is not number.
On the V6 dist cap, wire #1 is where the plug for the dist goes, it turns CCW.
The firing order for the v6 is easy, 1-6, passengerside plugs are 1,3,5 and drivers 2,4,6.
On a dist cap that has the angled plug sockets the order is 1,5,3,4,2,6.
Old Jul 18, 2013 | 04:05 PM
rokblok's Avatar
Off brand caps most times aren't numbers. And sometimes don't fit over the distributor properly, and even can have the terminals a few degrees off, which can affect timing.
Sleaker
Aug 26, 2020 06:03 AM
raptor510
Feb 17, 2017 07:11 AM
256mbaker
Jul 31, 2015 06:45 PM
msane99
Jul 17, 2015 10:13 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
