PDA
View Full Version : Newbie Tech Section
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
  1. fuel pump assembly
  2. does anybody havea 4runner with 2inch body 4inch suspension
  3. tire rubbing question
  4. Just purchased used truck, major issues to check for?
  5. 91 runner... engine gone?
  6. why is gas pouring out muffler
  7. tps write up?
  8. Which fuse
  9. Rear lift opinions
  10. L43 W56 Transfer case mounting???
  11. Clutch Noise
  12. v6 3vze oil pan gasket?
  13. oil cooler
  14. Post-Drain Problems
  15. Vortex Muffler
  16. 15" tires on 16" wheels?
  17. Needed: Front brake job write-up with pics
  18. Shock Recommendations for On-Road Use
  19. my 4runner is bouncy
  20. Noob question - suspension lift
  21. Switching from 16" wheels to 15" Good/Bad?
  22. O2 Sensor Question
  23. Metric bolt hookup
  24. Grip Tape Pedals?
  25. gears???
  26. new to the forum and toyotas! need help
  27. Lift Kit Recommendation and Wheel with tire size.
  28. no diagnosis center
  29. headman header no egr tube
  30. Bad water leak
  31. I got a leak!
  32. My '98 4runner rides like a steamroller. HELP.
  33. Timing chain cover leaking on 22re
  34. Every time I turn on headlights engine misses
  35. 2nd/3rd Gen. Coils
  36. Real basic oil change question
  37. 91 4runner vacuum regulator valve??
  38. 95 4runner rear bumper removal
  39. 22re re build time??
  40. Winch question
  41. My wheels are peeling! Who do you like for replacments?
  42. Heater core replacement in 91 toy pick up.
  43. locker interchangability
  44. truck problems
  45. Towing a uhaul 1200 miles...
  46. saggy bumper!
  47. Sector gear adjustment?
  48. torsion bar question?
  49. 35"s on stock height ifs??
  50. Trail Gear Trail Creeper gears
  51. vibration when braking after new rotors and drums
  52. Tacoma Computer Replacement
  53. New Plate Ideas
  54. Problems with my 3.0?
  55. 99 4 runner check engine light
  56. What is "add .4 liters of displacement? increase gas mileage
  57. '98 4Runner Owners Manual - Where to get?
  58. does anybody have a 90-95 runner with a 4inch supsension 2inch body on 35's
  59. Help Transmission Fill Plug??
  60. 96 4runner exhaust
  61. engine wont stop running
  62. Need info/advice 88 pickup 22RE
  63. 2000 Tacoma 4x4 Frame
  64. Repaint engine bay with engine in?
  65. fj80 front axel
  66. Idle Up Valve
  67. Throttle Body Spacer - Removing It
  68. used or rebuilt?
  69. Yet another code 52, knock sensor
  70. 2002 tacoma t-case
  71. 93 4Runner - R134 AC conversion?
  72. Need differential advice
  73. Ring & Pinion gear ratio?
  74. LAME POST: Need kid-friendly lift/susp/exhaust reco for '88 V6
  75. no compression in cylinders need help
  76. 99% sure I had a spun rod bearing, 2 months later the noise just went away?
  77. Pre runner 3in lift
  78. Lifting your truck..
  79. starter freewheeling, timimg belt broken??
  80. just started buldin motor 22r
  81. 2000 4runner hood scoop
  82. 2000 sport cheap power gains
  83. Drivers side window replacement
  84. TC Replacement, now HG & Valve Job (22RE)
  85. Can i drive without my front sway bar installed??
  86. Horrible MPG
  87. Shake at around 50 mph
  88. 3vze timing belt super loose.
  89. Muddy engine bay
  90. 91 Pick up to 4Runner Body Swap??
  91. Do 2wd & 4wd pickups have same bed??
  92. best shocks for a 2nd gen 4runner
  93. Rotor, hub, bearings and spindle
  94. 22re T-chain replacement gone wrong. Help!
  95. Should I replace the bearing and the race together? YES
  96. carb problem n e mechanics here please help?
  97. 4" ifs lift question
  98. AAL Question
  99. ball joints touching spring
  100. 1992 Pickup 4x4 22RE overheating questions
  101. Tires for my truck!!!!!!!!!!!!
  102. '93 Toyota Pickup Long Travel Tips
  103. Starting Issue
  104. just flushed brakes and pedal is all goofy
  105. 22re head replacement ????'s
  106. Axle seal leaking how bad to replace
  107. Replacement seats?
  108. Big enough Lift to fit 36s
  109. 35's
  110. A few good newbie questions
  111. Which friggin 5spd is the one I need?
  112. Buy Wrecked GMC 4x4? for swap into 88 runner
  113. Engine Swap Question
  114. Looking to do a rotor disc job, is there a good write up?
  115. rebuild
  116. engine code P0401
  117. Best gasket maker for cold application?
  118. Gas Gauge question
  119. 87 4Runner Clutch Master & Slave
  120. 1986 4-Runner wont start! help!
  121. 87 4Runner 22RE Help Needed
  122. somthin about 4runners
  123. Problems with removing rear shocks.
  124. Instrument cluster blunder
  125. 1987 4Runner Auto Questions
  126. perfect 85 runner setup?
  127. 89 3.0 v6 negative distibutor
  128. Sway Bar Links!!!
  129. newbie here, wheel spacer questions
  130. can i do away with the smog stuff when adding an LCE header?
  131. And so it begins... 89 22RE PU.
  132. Post-Lift Suspension
  133. EGR Cleaning Mega-Thread
  134. random misfire help!!
  135. Can't install snap ring on front axle.
  136. Remove Fuel Injectors
  137. 96 4-runner TPS code thrown
  138. New to me 86 toyota pickup.
  139. 1988 2wd P/U with transmission leak!
  140. Hub Help
  141. 1993 Toyota 4x4 22RE Turbo Tips
  142. 2wd 4runner with ARB airlocker question
  143. Tundra/Land Cruiser Lift Question
  144. help with code po171 and 306
  145. Will the Insurance Company Total '06 Tacoma
  146. Steering upgrades??
  147. Lifting My 2wd 4Runner: What Do I Need?
  148. What gears do I have?
  149. california high steer fab
  150. tube light mount
  151. Head Gasket Replacement - Help!
  152. 22r to 22re swap
  153. Making New Door Panels ?.
  154. Open Vacuum ports
  155. Changing differential fluid in 1984 Toyota 4Runner
  156. What happens when a truck sits for a couple months?
  157. bolt pattern 09 tacoma
  158. please help wont stay running
  159. Opinion of lifting a 3rd gen
  160. 22ret engine
  161. leaf spring questions
  162. head gasket replacement
  163. what size are the tcase mount bolts?
  164. 4WD gear sequence?
  165. 1986 pickup fuel?fire problem.
  166. HELP ME i need ideas
  167. tube bumpers help
  168. 1991 Truck Wont Always Start
  169. 90 4runner woke fire up
  170. Engine Rebuilds
  171. Suspension Height Question 2WD vs 4WD 4Runners
  172. AC stopped working. where do i start
  173. What is this damage from?
  174. Tacoma lift questions!
  175. Bilstein 5125's for stock '99 coils...HELP!
  176. 91 Pickup- Runs rich when first started.
  177. 22R Head Gasket
  178. 22re lack of power
  179. Stock Height Shocks for 99 Prerunner
  180. What in the heck is this? 22R question
  181. 87 4runner suspension question........
  182. front end shakes bad!!!!!
  183. Coolant Reservoir
  184. MAF with regular filter?
  185. Someone blew out my rear window, got write up?
  186. need help with my '92 - shaky brakes
  187. chilton's manual sucks!
  188. coolant temp sensor
  189. Looking for suspension advice for 02 4X4 4Runner
  190. New Vibration
  191. 1991 4runner AFM
  192. 1991 4runner 3.0 B+ hot sometimes and not sometimes
  193. OBD Tools
  194. Newbie with a project
  195. Fuel Issues? help needed
  196. O2 sensor problems
  197. Won't shift into 4wd...
  198. 1990 toyota pickup
  199. Shifter boot question
  200. 22r Distributor Vacuum Advance
  201. A question for everyone that has ever tried to get more out of a 3.slow
  202. wich axles should i use?
  203. Help with fuel leak: 1988 landcruiser
  204. 1991 4runner.Runs only with Fp to b+
  205. 2010 4Runner manumatic shifting (manual mode). Do I understand how it works?
  206. a question about 87-95 4x4 pickups
  207. Need help on performance(or not) brake rotors for may SAS
  208. 1988 3VZE motor part question - STUMPED
  209. T100 parts?
  210. '88 4runner runs poorly
  211. Does front prop shaft always turn?
  212. idle issues!! dont know where to post, any info would be great!!
  213. Transmission hesitation
  214. truck wont stat... No power to dash or cluch cancle button... nothing doen please hel
  215. solid front axle any good?
  216. Replacing alternator and radiator HELP!
  217. Clutch issues!!!!!
  218. sas?
  219. Use ATF not Power Steering Fluid
  220. 8922re swap into 8822re hole-HELP
  221. carb issues
  222. 87 strip down, what to take...
  223. 85 Diesel Wont Start!
  224. Which Chilton's Guide?
  225. 1980 4x4
  226. Intro/02 sensor question!
  227. thinking of getting OME lift, need input.
  228. Dual T-Case Question
  229. replacing shock bushing?
  230. Help changing 86 4runner fuel pump
  231. strange knocking noise and stuttering
  232. Going keyless, disable ignition lock
  233. What's that smell? 2010 4Runner. Clutch or new engine.
  234. 92 runner 22re excessive oil consumption
  235. headlights problem
  236. Noobie 4runner owner here with some questions
  237. v6 tcase bearing and seal?
  238. help with drive lines
  239. intake for injected 22re
  240. Need Steering Wheel Gudiance..
  241. YotaTech's Glossary
  242. 1992 4runner sterring assist
  243. Clinometer bulb size?
  244. Newbie Build up questions?
  245. rotor removal question 1980 4x4
  246. im new here and need a lift
  247. shock suggestions
  248. please help (twin sticks)
  249. Bike rack into spare tire carrier?
  250. obx header
