Sponsored by: CARiD
Clutch Noise
Old Mar 3, 2010 | 04:29 PM
YotaRiley's Avatar
Clutch Noise
I am having problems figuring out what this pop noise is when I am getting into 1st gear. If I let out the clutch EXTREMELY slow it won't do it. It feels like it has to pop into it but then its good. The tranny is good, so I am confused. Any help?
Old Mar 4, 2010 | 07:22 PM
komh98's Avatar
Sounds like the throw out bearing is going out. Is it making any grinding noises? I know mine didn't make any noise for awhile. It wore the clutch fingers out then started grinding. Guess when the bearing finally locked up all the way. I hope that helps you out. Michael
Old Mar 4, 2010 | 07:45 PM
myyota's Avatar
It could be anything from a bad throw out bearing to a broken spring on the clutch it self. You will probably have to pull the trans to see what the problem is.
Old Mar 5, 2010 | 06:28 AM
YotaRiley's Avatar
Thanks guys. I knew it wasn't normal. My friend has a shop and just curious how easy is it to change a clutch on an 85 4runner?
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
lmobeats18
Aug 28, 2015 04:57 PM
Dakotaneu
Aug 15, 2015 07:24 AM
norcal98
Aug 10, 2015 06:20 AM
PlayAwhile
Jul 20, 2015 11:36 AM
