Sponsored by: CARiD
Going keyless, disable ignition lock
Old Feb 1, 2010 | 10:49 AM
4xmtntoy's Avatar
Wink Going keyless, disable ignition lock
I want to make my 5spd 98 4runner work without a key, ie no key needed to enter, turn on and start vehicle. My plan is to install a keyless entry/alarm system, a switch to turn vehicle on, and a push button to start engine. The only obstacle in the way is the ignition lock that requires a key to free up the steering wheel. Does anyone have insight into how to disable the ignition lock? Is this a bad idea? Any feedback would be helpful.
Old Feb 1, 2010 | 11:00 AM
JasonWin's Avatar
I think it's a bad idea to get rid of the key to get into the vehicle. Always good to have a mechanical backup for something like that. What happens if your battery goes dead. how are ya gonna get into the vehicle?
Old Feb 1, 2010 | 11:29 AM
4xmtntoy's Avatar
There will still be door locks and a keyed ignition, I just want key use to be optional. My thought is to emulate the Toyota Prius - it's keyless to operate with a push button to start. However to start the vehicle you need the remote key fob on hand because it makes use of a proximity sensor to enable the ignition system/ turn on the car. I'm not sure I can do the proximity sensor thing. Obviously I am aware making the car keyless to turn on that it would be much easier to steal. I will hide the start button and an alarm system should deter theft.
Old Oct 4, 2011 | 04:22 PM
Boone1911's Avatar
Did you ever go keyless???
Sounds interesting, how did it turn out???
theking11863
Mar 19, 2016 09:36 PM
jeffold13
Sep 29, 2015 10:31 PM
kapeket
Aug 23, 2015 12:51 PM
jmyer72
Aug 20, 2015 07:55 AM
TDonkey
Jul 26, 2015 10:14 AM
