Sponsored by: CARiD
help with drive lines
Old Jan 30, 2010 | 08:16 PM
soyer's Avatar
i just bought a toyota and the shop hear in town wants $300 just to stretch my rear drive line 6"... i need any kind of help... cheaper place to get it done, or a way around this... or just some one that has long drive lines for sale i need front and rear...
Old Jan 30, 2010 | 08:59 PM
CappyKD's Avatar
Why do you need to do this? Some details about your rig would be helpful....
Old Jan 30, 2010 | 09:03 PM
tc's Avatar
tc
x2 - in particular, ho sure are you that you need 6" more?
$300? That's steep. Might try calling High Angle or Tom Woods at that rate ...
Old Jan 31, 2010 | 08:23 AM
soyer's Avatar
im not real shure on the 6" just what the kid i bought it from said... it a 85 truggy project, im not shure on how much lift... has coils in the rear with a 4 link... when i bought it the drive line was in the cab with a ton of other parts... and i was told that it needed 6" more
Old Jan 31, 2010 | 04:24 PM
tc's Avatar
tc
Measure from flange to flange with the suspension fully compressed and drooped, then measure the driveshaft all the way in and out
Old Jan 31, 2010 | 07:39 PM
soyer's Avatar
what i have now is a 48" drivedrive line and at ride hight it 60"...
Old Jan 31, 2010 | 09:03 PM
tc's Avatar
tc
Huh? You're gonna need a bit longer than +6" then ... you need to do the measurements as I described. Best case, the driveshaft is too short and you separate it under droop. Worse case, you make it too long and punch though the back of your tcase (making it EXTREMELY difficult to get off the trail).
Depending on the link length and placement, you could have almost 0" driveline length change or a bunch - and it will be unique to your truck.
It all costs the same regardless of how long you have the shaft made, so take the time and order the right length.
Old Feb 4, 2010 | 04:36 PM
eddieleephd's Avatar
I have a question what is the length of the slip yoke??
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
Sep 4, 2015 09:27 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
