Sponsored by: CARiD
What gears do I have?
Old Feb 14, 2010 | 07:30 PM
mlrtime99's Avatar
I'm having a brain fart. For some reason I feel like my 4runner (91 SR5 V6 4x4) has 4.88 gearing but I can't remember where I got that info from. Where can I check this?
Old Feb 14, 2010 | 07:31 PM
runneroffroad's Avatar
http://www.brian894x4.com/Gearratiosanddiffs.html
Old Feb 14, 2010 | 07:48 PM
mlrtime99's Avatar
Hmmm G254 which shows 8" 4.55 and open diff. I swore I had 4.88 in there, anyone else with a stick tell me what speed you get in 5th gear at 3500rpm on 31"? I'm right at 65.
Haha, my 69th post
Old Feb 14, 2010 | 07:57 PM
kiyobrown's Avatar
https://www.yotatech.com/forums/f116...osting-204178/
G254 is 4.56's
You put your engine down but not if its an auto or 5 speed. Since it says G254, I am gonna say 5 speed.
Never mind, your second post says stick.
4.88's are more common to find stock in a V6 auto.
I have 4.56's and 31's, and I run about 3100 rpm at 70
Old Feb 14, 2010 | 08:36 PM
speedwagon86's Avatar
Put all your info in here. It also lets you see what changing tires and/or gears would do to RPMS and road speed.
http://www.grimmjeeper.com/gears.html
Old Feb 14, 2010 | 08:49 PM
kiyobrown's Avatar
again, read the previous post. grimmjeeper is in there along with everything else you should need.
Old Feb 14, 2010 | 08:54 PM
BigBluePile's Avatar
what about unimog axles?
kiyobrown's Avatar
That was your dept, still waiting on that sticky.
Old Feb 14, 2010 | 08:58 PM
WOW 3 RB4Rs on this thread haha
wait you mean theres a STICKY for gears?!?!
Old Feb 14, 2010 | 08:59 PM
kiyobrown's Avatar
I know!! I was proud I made a sticky and no one uses it?
Old Feb 14, 2010 | 09:02 PM
kiyobrown's Avatar
Me and Logan travel together alot. I am the tunnel rat, he is the step stool.
hi/low combo takes out a knee then hits you in the face!!
Old Feb 14, 2010 | 09:18 PM
Windsor's Avatar
Just to add to the info-porn, here are three more links related to Toyota gearing/differentials:
http://www.off-road.com/trucks4x4/ar....jsp?id=274535
http://www.4x4wire.com/toyota/faq/parts/
http://home.4x4wire.com/erik/diffs/ (more about carriers than gears)
Old Feb 14, 2010 | 09:21 PM
kiyobrown's Avatar
GUYS!!! The sticky in the 86-95 section has every single one of those links in it.
Lets try this again..........................
If you have a different link that is not in the sticky and should be, please post it in the sticky so I can update it. Thank you.
Old Feb 14, 2010 | 09:26 PM
Windsor's Avatar
Red face
Old Feb 14, 2010 | 09:30 PM
Why?
Old Feb 14, 2010 | 09:34 PM
kiyobrown's Avatar
Maybe bc 99% of my posts are some sort of attempt at humor? I'll just go with that. No biggie fellas, not trying to be a jackhole, I just spent some time putting it together bc it took me a while to hunt down all those links whenever I needed em as well, I just want everyone else to benefit too. I don't need my own private sticky.
Old Feb 15, 2010 | 06:06 AM
mlrtime99's Avatar
I knew there would be but the search turned up nothing (this one is third on the list though if you search "what gears do I have". Has anyone noticed the search function has been out of whack lately?
Old Feb 15, 2010 | 10:08 AM
kiyobrown's Avatar
If you search an entire question, it limits the amount of replies
" I am looking for a way to identify the gears in my 4runner". Will get less hits then
"gear info" or "gear identification"
and no biggie. I notice you posted it the newbie tech, that's why you didn't see it, if you would have posted in 86-95, it would have smacked you in the face before you tried to post a new thread, lol. Hope you found out what you needed.
Old Sep 8, 2011 | 08:16 PM
tacho75's Avatar
just for the info.
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
