Sponsored by: CARiD
Instrument cluster blunder
Old Feb 19, 2010 | 01:25 PM
gscovill's Avatar
I'm converting an SR5 instrument cluster into my 85. Turns out the one I bought is for a 6 cylinder. Is there any way to convert the 6 cylinder tach to a 4 cylinder?
Old Feb 19, 2010 | 02:13 PM
4Crawler's Avatar
Here is a 4cyl->6cyl conversion:
- http://www.mindspring.com/~jayk3/toyota/tachmod.htm
Old Feb 19, 2010 | 02:28 PM
gscovill's Avatar
Thanks for the response!
This conversion goes the wrong way. The tach is a 6 cylinder and the engine is a 4. The instruction at this link is the other way around. I need to make the tach read higher on the scale by 1/3.
Old Feb 19, 2010 | 02:36 PM
4Crawler's Avatar
Correct, that is why I indicated it was a 4->6 conversion. Likely you can recalibrate the tach in the same manner, just adjust in the opposite direction.
xxxtreme22r's Avatar
should be same process only backwards, he mentions that the original is 42.5k ohm and the v6 is 31.1k ohms
Old Feb 19, 2010 | 03:11 PM
gscovill's Avatar
Good grief. Perhaps I should read the entire instruction before assembling my next nuclear power plant.
I'll give it a go.
Thanks!
Old Feb 19, 2010 | 03:13 PM
gscovill's Avatar
Some mornings it's not even worth chewing through the leather straps.
Old Feb 20, 2010 | 10:56 AM
gscovill's Avatar
It turns out that mine has a different circuit board entirely. And there just happens to be a calibration adjustment. Dialed right in. No problem.
I believe this cluster is out of an '86 because if was calibrated for a v-6... ?? It was sitting on the shelf at the Yota Yard in Denver so I'm not 100% sure. The web site listed in the response above referred to a procedure for an '85 tach.
thanks for getting me pointed in the right direction!
Old Mar 20, 2010 | 11:49 AM
HRDC0R19's Avatar
I want to get a cluster from the yota yard in denver. how did it work out for you? I dont have a trip odo or a tach in my cluster and want both. any ideas. I have a 86 4runner with a 22re and 5spd.
Old Mar 20, 2010 | 06:11 PM
garthscovill's Avatar
Mine is working extremely well. Completely satisfied. Easy conversion. All I had to do is swap out the cluster, swap out the oil pressure sender, and then recalibrate the tach.
TheBFA
Feb 15, 2020 06:55 AM
Jdgarrison
Oct 1, 2015 05:22 PM
87SR5justin
Sep 15, 2015 06:48 PM
imhousing
Sep 10, 2015 02:04 PM
Rawwdz
Sep 6, 2015 09:03 PM
