Sponsored by: CARiD
L43 W56 Transfer case mounting???
Old Mar 3, 2010 | 06:35 PM
komh98's Avatar
I have a 1980 Yota with a W56 Transmission with a transfer case mounted now. Will a transfer case from a L43 Transmission out of a 1979 Yota mount to it? I am planing on running duel cases. I have done some searches but have found nota. Thanks Michael
I think it is a W56 transmission I have in my 1980 Yota. I know it is a top shift. I ordered new shifter seals for the shifter to get the slack out and the parts were right. I was also told by the guy I bought it from it was a W56 but you know how that is sometimes.
Old Mar 5, 2010 | 04:06 PM
komh98's Avatar
Ok I made some phone calls today and come to find out yes it will work. The transfer cases are the some just the transmissions are different. Well Dual cases on the way now. I bought a 79 Yota today and all is well. Thanks Michael
Old Mar 5, 2010 | 05:30 PM
dropzone's Avatar
Fossilized
one way to tell if it is a w56 is there has been some modifications to transfercase crossmember, it would have needed to be moved back about 4 inches or so. L series transmissions are shorter.
also before you go slapping dual cases together make sure you are the correct input shaft on the case from the '79...some of them were different and are not compatible with out some work to the splines:
I found this info in this thread on Pirate
basically you want to check the tc input shaft before you go cramming the cheap deal of a TC into an application other than a 4speed L43
though commonly thought not all RF1A TC's are created equal
Originally Posted by TOYOTAPARTS
Pretty common symptom when an early input is used. The input from a 79 or 80 t case has an input that is not good to use unless you grind it down or replace it. Here is a pic of the one you want grind on or stay away from.
Originally Posted by BigMike
Check Dave's picture above. All inputs are tapered at the end, but the inputs found behind a L43 4-speed (20R applications only) have an enlarged spline collar that mates with the fully splined transmission output coupler. When the next-generation L-series transmissions were introduced (L45/50/52), the output coupler was redesigned with a 1/2" counterbore (with no splines). This helps the transfer case input shaft find the transmission output coupler during assembly on the production line.
Toyota was probably damaging transmission output seals with that enlarged spline collar and were looking for a way to improve the design. We believe the 2nd generation 21-spline inputs are made from better metal therefore the strength of the splines were no longer needed, however we have not proved this theory. Another theory could be that Toyota wanted to include a "fuse" in the drivetrain.
Here is a picture of the L43-style transfer case input I installed behind a Marlin Crawler W56A-HD 5-spd trans:
Old Mar 5, 2010 | 07:38 PM
komh98's Avatar
Thanks a bunch on the info. I tore into the case today and I will have to grind it. No big deal. I will get pics when I get it ready to go back together.
Old Mar 5, 2010 | 08:34 PM
dropzone's Avatar
Fossilized
when you grind it take your time so you don't heat up the shaft too much
Old Mar 6, 2010 | 06:04 PM
komh98's Avatar
I looked at my transmission today. I can't see any where it was moved back. I can tell the floor pan in the truck has been modified. Do you know the length of the L series transmission? I can tell you this it is a top shift 5 speed transmission.
Thanks for the hint on grinding. I will take my time to make sure it is right.
Chumlee780
Nov 13, 2015 03:18 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
yourrealdad
Jul 29, 2015 11:08 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
crashburnoveride
Jul 10, 2015 06:39 AM
