Sponsored by: CARiD
Open Vacuum ports
Old Feb 13, 2010 | 05:14 PM
Irish Death's Avatar
Open Vacuum ports
Well going through the new 4Runner. Noticing some missing vacuum lines. So i did some searching found this post over on pirate4x4: http://www.pirate4x4.com/forum/showthread.php?t=579557
Was quite helpful...except I don't see whats on my engine...
First one looks like similar to a VSV but has an extra port...
The 2 connected to that one, go here currently:
I know I'm missing the VTV from here:
Should I just cap it for now until I can snag a VTV or?
Just noticed one missing on this one...
need to run out and see if I can make sense where it should go...
There is a capped one on the backside of this one...
another random shot
The rig is an 86 5spd
Old Feb 13, 2010 | 07:34 PM
myyota's Avatar
The fourth picture down looks like the fuel presure regulator, there should be a vacuum hose from the upper intake that conects to it. There is normally a vacuum switching valve hooked inline from the intake to the fuel presure regulator, but its not needed. I have my fuel presure hooked up right to the upper intake manifold.
Old Feb 13, 2010 | 07:39 PM
kiyobrown's Avatar
Easiest thing to do is find someone with similar motor and side by side compare with them. I went up to Truckfiend's place this week to do the same thing. He had a couple things different then mine, but Deathcougar over at Nix99 and his infinite knowledge told us it was the difference between A/C and no A/C, and had the right parts to steer us in the right direction. We still had to run a couple of lines and reroute others.
Old Feb 13, 2010 | 07:41 PM
myyota's Avatar
Its hard to tell from your picture, but in the fifth picture, the vsv thats capped off, that looks like were the fuel presure regulator should be hooked up to. Like i said before, you can remove this vsv and hook the fuel presure regulator straight to were the vsv is conected on the intake, but if you want it hooked up the way it was stock then just remove the cap and run a vacuum hose to the regulator.
Old Feb 14, 2010 | 11:15 AM
Ok so I hooked up the FPR in pic 4 to the capped port on the VSV in pic 5. Now I just have the one open port on pic 1, which I've capped for the moment and then I just need to get the VTV for pic 3? Should I cap this for the time being or let it flow?
Old Feb 14, 2010 | 01:38 PM
myyota's Avatar
Picture three doesn`t hook up to anything, it normally has a short piece of hose conected to it with a check valve on the end of it just hanging loose, but it won`t hurt anything with nothing being there as it is now.
Old Feb 14, 2010 | 01:41 PM
yep got it all figured out runs a wee bit smoother now...it ran smooth in the first place but just runs smoother now
Thank ye thank ye!
Old Feb 14, 2010 | 02:00 PM
myyota's Avatar
In picture one the vacuum hoses are hooked up wrong, the vacuum hose at the top by the electrical plug is in the wrong place, it needs to be moved to the bottom vacuum port next to the other vacuum hose, the vacuum port at the top is actually a vent and is left open.
Blamalam
Mar 12, 2022 07:34 AM
wafoogalla
Nov 2, 2016 11:02 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
